What OT for a Pair of KT88's?
fusionbear
Post by fusionbear »
As the title states. Where can i get a transformer that is 100 watts but has the right primary impedance for a pair of KT88's. This is for my clean amp project. I think it needs 3300-3500 Ohms on the primary?
Learning to learn...
Hellhammer
Re: What OT for a Pair of KT88's?
Post by Hellhammer »
I think you need more like a 4500-5000 Ohm primary.
http://www.tubezone.net/pdf/kt88new.pdf
Hammond 1650R?
http://www.tubesandmore.com/scripts/fox ... m=P-T1650R
/Stewart
ToneMerc
Post by ToneMerc »
fusionbear wrote:As the title states. Where can i get a transformer that is 100 watts but has the right primary impedance for a pair of KT88's. This is for my clean amp project. I think it needs 3300-3500 Ohms on the primary?
At what plate voltage?
Hellhammer
ToneMerc wrote:At what plate voltage?
He'd need about 600 for 100W if I'm reading the datasheet right.
/Stewart
Alexo
Post by Alexo »
Not sure where you're getting 3K5, but to each their own.
I've used the Hammond 1650R for this setup and it worked great. Puh-lenty of headroom with that OT if you're building a clean amp.
You could also use a Hamm 1750U if you double up the load (3K4/100W).
FWIW, if I had it to do again, I might use a slightly lower plate voltage and run a quad of '88's to get 100W. JMHO.
Hellhammer
Alexo wrote:FWIW, if I had it to do again, I might use a slightly lower plate voltage and run a quad of '88's to get 100W. JMHO.
Interesting, may I ask why? They are quite expensive bottles, and I'm cheap! :D
/Stewart
Alexo
Post by Alexo »
Sure! Truth be told, I had a heck of a time actually getting 100W out of them. I think the closest I got in the real world was around 75 or 80, following everything the datasheets tell you to do and then some (560+ on the plates, 400 or so on the screens, 5K load, 465ma PT).
Just seems like the tubes had other plans, as they are want to do, 50watts+ is easy for a pair of them, better to play to their strengths.
But I hear you on the money!!
David Root
Post by David Root »
Edcor makes an 11 lb 3K5 OT rated 70W at 20 Hz to 20 KHz bandwidth, I got 100W out of a pair of 8417s at 520Vp thru it no problem. It would do 150W at 40-10KHz. $92.
Hellhammer
Alexo wrote:[I think the closest I got in the real world was around 75 or 80, following everything the datasheets tell you to do and then some (560+ on the plates, 400 or so on the screens, 5K load, 465ma PT).
I built an amp with the same specs except for higher screen voltage. I don't have the means to measure P out but I have a gut feeling it won't put out 100W clean. But I'm having other issues with it so hard to tell. That reminds me it still sits there collecting dust. That's a lot of money in iron, tubes and mustards. I should finish the amp some day! After the 1W SE amp I'm doing now maybe. :D
/Stewart
Alexo
Post by Alexo »
Right on. Well even at less than 100W, it is still LOUD. It's never come up short on power, and it's a gigging bass amp, so I guess that's saying something. The owner has since retired his 300W SS head, because it can't compete. :l
Easy to get hung up on the numbers, but no one really cares! :)
Have you thought about using KT120's? For a few dollars more, you'll probably be able to get 100-120W no problem from a pair. The tube appears to have good reviews.
jon
Post by jon »
What kind of driver circuit/PI are you planning on using. That can make all the difference in how easily you get to your desired output.
fusionbear
I'll be running at about +490 using standard Marshall 100 watt PT
Also, I don't need the full 100 watts out of them. If I get 60 "clean" watts out of them, I'm happy. I want the amp to still feel "bouncy". The KT88's have a nice bouncy feeling to them when run at these lower voltages.
fusionbear
David Root wrote:Edcor makes an 11 lb 3K5 OT rated 70W at 20 Hz to 20 KHz bandwidth, I got 100W out of a pair of 8417s at 520Vp thru it no problem. It would do 150W at 40-10KHz. $92.
This sounds right up my alley. Any pt# I should look for?
fusionbear
Hellhammer wrote:I think you need more like a 4500-5000 Ohm primary.
Hammond 1650R?
This also looks promising. Thanks!
