Guys trying to help a friend here. The amp works but the reverb only gets buzzy as the reverb comes up and no sound of the reverb pan when you shake it?
Any thoughts..... tubes are good.
Ange
AA270 Silverface Vibrolux reverb
Re: AA270 Silverface Vibrolux reverb
Did you try reversing the leads to the reverb pan?
Also if you have the amp use the reverb pan from your Reverb Rocket to test the Fender reverb circuit.
I just went through this with a Blues Jr I found a wire had broke in the pan. Luckily I had the exact pan in my junk pile.
