Looking for schematics with ef86 as V2 or V3
- Kagliostro
I'm looking for a guitar amp schematic that have an ef86 not as V1
but as V2 or V3
something like in the Matchless Clubman that uses a (paralleled) 12ax7 double triode as V1 and a 6SH7 pentode as V2
Have you schematic with the ef86 in that position ?
or do you know amps that use that architecture ?
Many Thanks
Kagliostro
but as V2 or V3
Many Thanks
Kagliostro
Re: Looking for schematics with ef86 as V2 or V3
Selmer Zodiac has EF86 in both channels as second stage :
- Kagliostro
Many Many thanks KT66
Kagliostro
Kagliostro
My cousin has a Selmer Zodiac. At least I think it is a Zodiac.
It is the size of a AC30.
It has these push buttons for different effects and tones.
Also has a "magic eye" on the front that glows green and to the beat of the vibrato or tremolo or rotating tone.
It is a very good sounding amp as a bonus.
- Kagliostro
Hi Structo
WOW I'll try to find photos of that amp !
thanks for the indication relative to that
Kagliostro
Kagliostro
Would you be driving a tone stack with the pentode? Just curious...
This one has always looked like a fun amp:
https://taweber.powweb.com/store/6s100_schem.jpg
- Kagliostro
Many Thanks also to you KellyBass
I want to build a stand alone preamp with a pentode not in first position, and also try to insert the pentode/triode control as from Merlin indications
Kagliostro
No, my interest was about to "study" this particular architectureWould you be driving a tone stack with the pentode?
Kagliostro
I believe that one of the Dr. Z amps also uses an EF86 in V2, after a 12ax7. Not sure which - Prescription maybe?
The good Dr. posts here occassionally. Perhaps he would give us some of his thoughts on this type of architecture.
That sounds like an interesting project! I've also read Merlin's chapter on small signal pentodes and am curious.Kagliostro wrote:Many Thanks also to you KellyBass
Kagliostro
Here's a good article to read:
http://www.dougcircuits.com/EF86.html
- Kagliostro
Thanks KellyBass
so happy you give it to me
Kagliostro
sometime ago I had that link but I lost
Kagliostro
also looking at a small pentode for V2
Thanks for that link, I have never seen that page before.KellyBass wrote:Here's a good article to read:http://www.dougcircuits.com/EF86.html
The link to the Selmer is great too, that opened up a whole new world!
If I understand Merlin's suggestions for the small pentode in V2 correctly it is to use it primarily for tone, rather than for gain. That's pretty cool.
Dingleberry
I have one schematic somewhere where EF86 was presented the V2 position. Never experienced with that though...
If I remember correctly it was like guitar into 12AX7 wired as a cathode follofer, TMB-tone stack, EF86 and volume control to SE EL84. I'll try to find it, haven't seen anything like that before actually.
Can some Guru enlighten me what are the pros and cons of having a cathode follower first in the signal chain?
-T
-T
- Kagliostro
Read thiswhat are the pros and cons of having a cathode follower first in the signal chain?
http://www.el34world.com/Forum/index.php?topic=154.0
there is a little but interesting explanation
Kagliostro
