Tubes used are:
V1- 6EU7
V2- 6EU7
V3- 12AU7 (with hum balance pot alongside)
V4- 7591
V5- 7591
V6- 5AR4
Transformers are:
input: 54-118 549-6407
and
output: 51-82 549-6407 tapped for 4-8-16ohm.
Control pots are simple volume, bass, treble.
I would like to convert it into a guitar amplifier. Anything strike you as to what would be doable? Suggestions? Too much for a first post? Should I wait for the schematic to scan it and post it first? I can read a schematic, but I do not have any training in amplifier design/theory except to know that I do need to be extremely careful of the power supply caps (to discharge them safely) and voltages in the amplifier performing bias setups etc... I am, however, trainable... Any takers?
 Boggs
 My first guitar design and build was a chambered body bookmatching the padauk top and back and chambered Cuban mahogany midsection without using so much as a router... It had a jazz style neck humbucker and a vintage rock bridge humbucker both tapped so you could select any individual or combination of coils... The neck was set back at 1.5 degrees... I'm not very bright, but I am sorta fearless...
