Tubes light up, B+ looks healthy, but zero sound.
So I looked up troubleshooting techniques on the output transformer and found I don't own a filament transformer and decided to shoot the easiest AC signal I could image into it.
Portable radio out the headphone jack to the primary, speaker hooked up normally.
Sound!
So I guess the OT isn't shorted out.
(Is that even a valid test???)
Snooped around for anything fishy.
6L6 cathodes are tied to ground through a resistor that tests 150meg.
Why?
Schem has a 10 ohm two watt resistor there.
Most amps I see are tied directly to ground...
Also...green wire and white wire are both soldered to the positive on the speaker jack but the NFB wire is disconnected and wrapped.
Think they got the two green wires mixed up?
Looks like the green is 8 ohm output, white is 16 ohm.
Thanks for any responses.
