Greetings all!
How do I calculate (or is it printed on the data sheet?) the resistance in a GZ34 rectifier?
									Resistance in rectifiying tube
Re: Resistance in rectifiying tube
Resistance *in* the valve? Do you mean plate resistance or minimum source resistance?
Plate resistance is app. 40R for a GZ34/5AR4, minimum source resistance depends on the actual supply and filter type used.
It should be typically at least 150R for a 400V supply and a 60µF cap in a capacitor input filter. Source resistance is the sum of the PT reflected DCR and of any added series R between the PT and valve.
Check for instance page 3, rating chart III in the GE 5AR4 datasheet.
http://www.drtube.com/datasheets/5ar4-ge1959.pdf
I don't know!FYL wrote:Resistance *in* the valve? Do you mean plate resistance or minimum source resistance?
I want to calculate how much more voltage would be available using a solid state rectifier rather than a GZ34. My understanding is that the resistance inherent in the tube drops some voltage, whereas the SSR does not.
IanG
OK, then it's plate resistance. A GZ34/5AR4 will typically drop peanuts to 40V depending on current thru it (remember Ohm's law?) - you can expect 16V at 200 mA, 20V @ 300 mA, etc., a standard silicon diode will drop app. 0.7V.I want to calculate how much more voltage would be available using a solid state rectifier rather than a GZ34. My understanding is that the resistance inherent in the tube drops some voltage, whereas the SSR does not.
The rule of thumb for voltage dropped from different rectifiers (which is 'close enough') is:
SS - 1.4142 x the HT VAC
5AR4 - 1.31 x the HT VAC
5U4G - 1.21 x the HT VAC
5Y3G - 1.11 x the HT VAC
See also the attached rectifier voltage chart courtesy of Billy Penn.
