I ended up going with 6SL7's instead of 6SC7's for a few reasons, namely that I have many more 6SL7's and 6SN7's and only 2 6SC7's (thought I had more..) and used slightly smaller plate resistors @ 220k vs. 250k in the original. I also used a 2.7k cathode resistor on the 2nd stage. I liked the idea of slightly less gain so that I could get a usable clean sound out of this amp without having to muck with the amps volume knob. It cleans up nicely using just the guitars volume but gets a great sounding distortion when cranked. I see why people are so crazy about the Tweed Deluxes, they really do sound great and it has a surprising amount of sustain!
The B+ sits at around 310V and the 6L6's idle at around 54mA giving me a plate dissipation of about 16.5W. It's definitely loud just through my test speaker so I'm thinking I will leave it as is as far as bias is concerned.
The only problems as of now are the amount of hum I get and the turn-on voltage spiking to over 500V. I installed a 250 Ohm hum balancing pot on the 6.3V tap which doesn't make a piss of a difference. The amp is usable in its current form but I'd like to figure out how to cut down on the hum a bit. I'm thinking it may have to do with the used and abused unmatched 6L6's I was using in the output stage, I'm going to try some better tubes and see if this cuts down on the hum. Since the transformer doesn't have a CT on the 6.3V winding, I can't use the elevated DC trick to knock down the hum.. The 500V inrush peak voltage is only a problem because the can cap I'm using is only rated at 450V. I'm going to use a PTC from the rectifier to the can cap to hopefully cut down this voltage spike to a more reasonable level. I'm very happy about that can cap working out so well though, it's a NOS Sprague unit from 1952 that leaked less than 300uA on both sides (it's a dual 10uF, 450V unit) before I reformed it. The leakage went down a bit more after reforming which was quite surprising to me.
I did this build point to point but was careful to plan it out and not rush through anything. I must say I'm very happy with the results considering this was a completely free build
Also notice the strange Vitamin Q cap I used on the input. It has one lead coming out the bottom and a threaded outside connection. I ended up just soldering the 68k input resistors directly to the top of it. Seems sturdy enough, at least for now.
Here are some pics:
