Has anyone had any experience with these tubes? I found a thread talking about the 6P14P's and there was a mention of the 15P's, but not much info.
Anyways, I found some on eBay a couple weeks ago while searching for NOS EL84's, did some research comparing the pinout and specs with the EL84, and picked up 20 of them for a *really good* price from a seller in Moscow. I half-way expected them not to show up, but it was only ~$60 and he had great feedback and has been selling lots of tubes, so I took the chance.
Well, they show up today and I popped them in my 18 watt junker/testbed, and they sound really nice! Have a nice low end to them which is unusual IME w/EL84 type tubes.
Looks like the only connection difference between the EL84 and this tube is that the '84 has the screen that sits next to the plate wired to the cathode (pin 3) internally, where these 6P15P's have that screen wired only to pins 1&6 which are normally unused in an EL84 (please correct me if I'm wrong here).
So, a few questions:
Should I wire my sockets so the outermost screen is connected to the cathode so the connection and operation mimics an el84? What do I lose without that connection being made? They sound fine as is... I figured there would be no harm done even with el84's installed as they don't use those pins, correct?
Does anyone have any experience with these tubes, and if so, I'd like to hear your opinion of them. To my untrained ear, they sound really nice: sort of dark for this tube type, really smooth, and with a nice satisfying growl when you just start to overdrive them. I'm going to try them in my Rocket clone later on.
Some more info: These were made in Saratov at the Reflector plant, the date code is May 1985 and they are stamped "OTK" signifying a military designation from what I can find on the net. They are in unopened boxes with spec sheet inside (very cool!). All in all, I think it was a nice buy, and I'm considering getting some other tubes from him (6L6/5881 and 6SL7 types, also nos)
I'd like to hear any comments. Thanks!
6P15P-EB Saratov tubes
Re: 6P15P-EB Saratov tubes
I've never used them, but have occasionally seen OTK versions for sale as cheap as $1, so it's hard to go wrong. As near as I can tell, they are ALMOST direct subs for EL84/6BQ5, but there are differences even between brands of EL84/6BQ5s. It has to do with whether pins 1, 6 and 8 are internally connected to anything. Some 6BQ5s have an internal connection between pins 1 and 2. Some 7189As apparently have the screen connected to pin 6. So the caveat is: if you wire your sockets to have the suppressor grid on pins 1 or 6, double check any EL84 before substituting it into the amp. Most times, substitutions will be fine (like most EL84s work in sockets wired for SV83s), but there will always be an exception.
Aren't these Saratov's that ones that Terry has been selling a lot of?
The 6Π15Π / 6P15P is a video pentode quite close to the 6Π14Π / 6P14P, itself very close to the EL84 / 6BQ5. It was exported by the real Svetlana (SED =C=) as the SV83. The 6Π15Π-EB / 6P15P-EV is a ruggedized version.Has anyone had any experience with these tubes? I found a thread talking about the 6P14P's and there was a mention of the 15P's, but not much info.
Here's the SV83 datasheet:
http://www.drtube.com/datasheets/sv83-sed1997.pdf
And a Svetlana application note:
"Using the SV83 in EL84 Amplifiers
By: Eric Barbour
The Svetlana SV83 is a 12-watt power pentode which is well-suited for audio use, in either guitar amps or in high-fidelity equipment. Its original design, intended for high-accuracy video amplification, gives the SV83 high transconductance and very high linearity. The SV83 may be used in any EL84 or 6BQ5 circuit, provided that some changes are made as described below, in items 1 thru 4.
1. There is a small difference in the pinout of the SV83 versus the EL84. SV83s may not have their suppressor grid connected to the cathode internally. To insure the usability of all SV83s in an EL84 socket, do the following:
a) Insure that pins 1 and 6 of each SV83 socket are NOT connected to any circuitry, nor used as a tie point for components.
b) On each SV83 socket, connect pin 6 to pin 3, using a short wire jumper. Be sure the wire does not touch any other circuitry.
(Note: there is an issue with the pinout of SOME EL84s versus the SV83. See item 4 below.)
2. The SV83's screen grid (pin 9) is not able to accept an operating voltage of more than 200v DC. Because nearly all EL84 amps operate their screen grids at or near the plate voltage (in pentode, ultralinear or triode connection), the amplifier must be modified to provide a lower voltage to the SV83 screen grids. If triode connection is desired, the plate supply voltage must be limited to 200v DC. For higher plate voltages, any of the following circuits will work:
[img:673:462]http://www.tube-town.net/info/sed-techn ... 29fig1.jpg[/img]
a) Figure 1 is probably the lowest-cost method of deriving a screen voltage. This works adequately for most guitar amps and some vintage hi-fi amps. The screen voltage can "sag" when full power is reached, although this may not be an issue, especially in a guitar amp. A major advantage of this scheme is that the resistive divider also acts to discharge the power-supply filter capacitors when power is turned off. This circuit may be used with a single SV83 or one pair of SV83s. It adds about 15-20 mA of current drain to the plate supply, which must be allowed for in the power transformer.
[img:740:460]http://www.tube-town.net/info/sed-techn ... 29fig2.jpg[/img]
b) Figure 2 is the best solution for high-end audio design. The zener diodes are a low-cost option which offer good regulation and good stability. The types shown are rated for 1 watt dissipation and are operated conservatively here. A filter capacitor may be paralleled across them to assist regulation if desired. Using the 0A2 gas regulator tube is a possible all-tube technique to achieve the same result. Although 0A2s are out of production, they are long-lasting and readily available in bulk quantities as NOS. Gas tubes can NOT be used with a parallel capacitor larger than 0.1 uF, as zeners can. The choice of which regulation method to use is up to the designer. This circuit may be used with any number of SV83s up to a quad.
3. Bias adjustment may be necessary to obtain the same plate current with SV83s as with EL84s. Typically the SV83 will require about 1-5v less negative grid voltage than EL84s for the same idle point, due to the higher transconductance and sensitivity of the SV83. If cathode bias is used in the amp, the cathode resistor may be decreased in value about 20%. The designer is urged to equip the amplifier with SV83 and try it without bias adjustments, as the resulting bias value may be acceptable. No modifications to driver circuits are required.
4. An amp which is modified to accept SV83s can be made back-compatible with EL84 types. First, a switch must be provided to DISCONNECT pin 6 from pin 3. (This is necessary because SOME EL84 and 7189 types have internal connections to pins 1 and/or 6. Many EL84s do not. This can cause some confusion.) Second, the idling plate current of the EL84 will be lower in the SV83-modified circuit. The switch above may use a second pole, whcih can be equipped to switch in different cathode-bias resistors. The switch can then be set to allow proper operation with SV83s or EL84s.
revised 10/98"
Cool, I appreciate the info, thanks!
Tom, I'm pretty sure Terry was selling the 6P14P-EB which has the internal connections just like an EL84, unlike these 6P15P's, which in this case, makes the 14's more desirable.
Rob
