Ab763 simplified design
Lynxtrap
Re: Ab763 simplified design
Post by Lynxtrap »
Mikante wrote: Mon Jun 19, 2023 12:35 pm I see the 372bx has a 50v out, damn it is way more expensive too :cry:
For me to better understand, the princeton transformer has 2 secondary and one is 550vac and you said that this one was sill a bit high, i guess you were referring to the 630vac out right? Then why is the 372bx a better choice? Mainly for the 50v out?
I d like to understand because the difference between 600 and 550 is not that much, in my head at least.
You are not limited to the Fender replacement units, have a look at their more generic series also.
My go-to supplier in Europe announced just last week that Hammond had raised the prices by up to 100%! So perhaps check out other alternatives too.
"Hey mister, turn it on, turn it up, turn me loose!"
270CAX is a generic PT, not necessarily a Princeton replacement. 550 VAC is a bit low; I'd guess the DC voltage at around 370. I like 372BX for hitting the correct voltage, its upright mounting (no large chassis cut-out), and the 50V bias tap. The lower voltage taps on the 270CAX would work, and a bias circuit like the Princeton uses would be easy enough. Is your local line voltage 240?
Lynxtrap
Post by Lynxtrap »
martin manning wrote: Mon Jun 19, 2023 2:06 pm 270CAX is a generic PT, not necessarily a Princeton replacement. 550 VAC is a bit low; I'd guess the DC voltage at around 370. I like 372BX for hitting the correct voltage, its upright mounting (no large chassis cut-out), and the 50V bias tap. The lower voltage taps on the 270CAX would work, and a bias circuit like the Princeton uses would be easy enough. Is your local line voltage 240?
He is in Italy so that rules out the 270CAX, it's limited to 120V primary. The 372BX comes with universal primary.
Lynxtrap wrote: Mon Jun 19, 2023 1:25 pmThey do tend to read higher than the schematics, but not that high under normal circumstances. I would however be surprised to see a reading below 415V unless biased very hot (I'm not familiar with the reissues).
I don't know about where you are, but voltages in the US have crept up over time, so amps from decades ago run at higher voltages. I look at the Fender Reissue series as their attempt to replicate the sound of the originals running on modern line voltage, and they chose to go with just under 400 VDC for the '65 DRRI.
Lynxtrap wrote: Mon Jun 19, 2023 2:12 pm He is in Italy so that rules out the 270CAX, it's limited to 120V primary.
Yes, I meant to say 290CAX, as in the data sheet posted above.
Mikante
Post by Mikante »
Lynxtrap wrote: Mon Jun 19, 2023 1:40 pm
I know, with my experience it was easier to search for fender replacement. I understand what to look for now thank you.
About the prices, still normal for now. They are already incredibly expensive and i really don t understand how could a company double their prices from one day to another, i mean double. The 372bx would then go for 270 euros, insane.
Yes
Mikante wrote: Mon Jun 19, 2023 2:31 pmThe 372bx would then go for 270 euros, insane.
https://eu.mouser.com/ProductDetail/Ham ... y41MS4wLjA.
Mikante
Post by Mikante »
I usually buy from here, a little more expensive but they got everything so i don t have to pay further shipping costs by ordering from other sites.
As you can see the price is still ok.
Unfortunately i can not say the same thing about the warehouse speakers, they bumped the price not so long ago about 40%. I really like this brand, i have a veteran wgs 10 and i love it.
Lynxtrap
Post by Lynxtrap »
I'd guess retailers sell their stock at the old prices. Perhaps a good idea to buy before the new prices take effect.
Mikante
Post by Mikante »
That must be the reason. I hope they won t raise the prices any soon. I can t afford right now.
The overall cost is pretty hight once you collect all the parts. Tubes and components and everything, I m well above the 600 euro and I m not counting the cabinet because I am a wood worker and a got plenty of wood (which i pay anyway :lol: ).
Roe
Post by Roe »
Mikante wrote: Mon Jun 19, 2023 4:29 pm I usually buy from here, a little more expensive but they got everything so i don t have to pay further shipping costs by ordering from other sites.
yes tube-town are great really
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Now what to do with the unused triode? Add the bias modulating tremolo from the 6G3.
A couple of other changes are shown:
The Brown channel plate and cathode resistors have been changed to 6G3 values to complete the Black/Brown Deluxe theme, and a 220k has been added to the Brown output to balance the overall gain of the two channels. Lastly, the Black channel now has a mid control.
Mikante
Post by Mikante »
I wanted to add the 6g3 tremolo circuit but then, i want adjustable bias so i decided i could live without.
I d like to keep it as simple as possible cause I already went too far with the two channels and phase problems.
Mikante wrote: Tue Jun 20, 2023 4:04 pmI wanted to add the 6g3 tremolo circuit but then, i want adjustable bias so i decided i could live without.
That's not a problem, the above schematic has adjustable bias. I just hate to see a triode go to waste.
Mikante
Post by Mikante »
martin manning wrote: Tue Jun 20, 2023 4:23 pm
Yes I noticed, I didn t know it was possible :mrgreen:
