Let's consider it for a moment, 10R resistors with a 1% rating will always be slightly better than a 1R for shooting in the shadows near the darkness, and possibly one order better, on average.
Steve, go to Metro's Wiki (
www.metroamp.com) and look at the JTM-45 build instructions. (.pdf)
It has a section on how the bias check resistor is mounted, and at the end of the build, it has first power-up, and biasing instructions. It also has expected voltages at all pins for their transformer setup. Your's will probably be different, but ballpark.
Use fast-blow fuses for startup, bias, and change to slo-blows Before you blow one and think you have a terrible problem.
Since we are cavemen, we don't use perfection this time. You don't have to wring the last .00034mV (on DC setting on your multitester with bias check resistors) for the amp to work well, or sound best. Within a couple mV is fine, as long as it's low. lol
When you increase bias current, tubes will show lower voltage by a bit, use that new voltage, rebias, use the new voltage, rebias, use that new voltage and rebias. Within about 5 trys from start, you will see the tiny bias change barely moves the voltage, and then you are done.
Relax. Be aware, but relax, take your time. The tubes aren't going to melt with a cold bias start, you have forever. Take your time. It's ok. Make sure you have lots of light, a clear path, and a steady hand. Relax. I was too freaked out to touch the guts of an amp up til about 5 months ago, and now I swap bias 10 times a day when I am swapping tubes.
Clear path, lots of light. Clear head. Relax.
Do pay more attention to your connection probe to resistor than to the meter. Place the meter on something just behind the upturned amp so you can see the probe and the meter at the same time. I use probes with a little ring of smaller diameter about a half inch from the tip so it kinda locks on the resistor leg in a positive way as long as you hold light pressure. No slipping, no worry.
Clear path, lots of light, clear head. Take forever. Relax buddy.
