Epiphone Pacemaker 50T PT short
maxkracht
Re: Epiphone Pacemaker 50T PT short
Post by maxkracht »
Looks like it's the normal kind of lamp assembly that can be separated, but grounding one side worked for the original, so should be fine either way.
Might be worth adding screen resistors if the plate voltage is going to be at or above the 6aq5s design maximum. Probably not a bad idea even if you get the voltages down to where it originally was.
angelodp
Post by angelodp »
Yes this amp has an assembly that would be tough to isolate. I looked at a fiber washer, but it seems iffy.
angelodp
Post by angelodp »
Good idea, 1k 3w screen grid resistors.
angelodp
Post by angelodp »
Still trying to source a PT for this Amp. Owner has this PT, but I cannot find any info. Might you know what this is. It has the usual black primary, red/redyellow plate connections for rectifier, and yellow leads for Rect. (I assume) and green leads for 6v no center tap. I doubt the heater winding is sufficient for this Epiphone?
Also have a 125P23B Deluxe reverb PT here from him. It's a bit larger but has the 3A current capacity for the heater wires. Voltage is high 330v but the zener method might do.... or is that just too much to drop.
Post by Stevem »
This is the way you have to do things at times to get a old invalid amp back on its feet and running.
A side benefit of this type of remote mounting is extremely low 60 hz hum!
One time I was forced to mount two separate transformers this way, one for the B+ and the other for filament.
maxkracht
Post by maxkracht »
No idea about your mystery transformer. Are the voltages close to right? Why do you think the heater isn't sufficient?
You can always bolt on a metal plate to the transformer cutout and install a vertical mount on top of the plate. You can even score and snap relatively thick aluminum with a hobby knife if you don't have many metalworking tools. Just takes a bit of patience and prep work. Admittedly, Steve's idea is probably easier if the owner doesn't mind it aesthetically.
chumchai
Post by chumchai »
Would you consider a toroid transformer? If so, then this would be a good match and the price $42 is right. I know, it doesn't have an "oldie" look. Steel cages are also available.
https://www.antekinc.com/content/AS-1T250.pdf
Post by Stevem »
It’s a great price for that PT because it only seems to provide.55A on the B+ secondary side.
That’s really only enough for something like a 5 watt champ if I am
Not mistaken .
chumchai
Post by chumchai »
Stevem wrote: Sat Sep 09, 2023 6:36 pm It’s a great price for that PT because it only seems to provide.55A on the B+ secondary side.
Not mistaken .
That is 550mA. How much does he need? It's a 100VA PT.
Edit: from the schematic, I calculated the amp needs about 91mA B+, with preamp tubes drawing 5 mA each.
Post by Stevem »
A tube amp power trans that’s rate at 100VA will typically output about 100 ma for the B+, he needs more like 150ma to 170 ma if you care to compare his amp to a blues Jr for example.
chumchai
Post by chumchai »
Stevem wrote: Sat Sep 09, 2023 6:36 pm It’s a great price for that PT because it only seems to provide.55A on the B+ secondary side..../cut
Again, that is 550mA to me. The 6X4 rectifier tube can only safely deliver 77mA steady current. Where is the rest coming from?
The schematic says it all and datasheets.
chumchai
Post by chumchai »
Fender Blues Jr. PT
https://www.tubesandmore.com/products/t ... unior-15-w
If I'm not mistaken, it says B+ 330VDC @ 68mA
Never mind, just saying.
angelodp
Post by angelodp »
Both PT's owner brought over are shorted. Back to square one. I am thinking just go for the hammond and be done with it. Appreciate all the follow up, clearly no hurry at all on this. We'll get it done.
A
maxkracht
Post by maxkracht »
That torrid has plenty of juice, I think Steve missed a decimal. They have a 200v one that would be a bit closer. https://www.antekinc.com/as-1t200-100va ... ansformer/
Hammond I recommended earlier isn't quite right, Thought it was 250-0-250 instead of 250v ct. That would put your B+ in the 175v range, a bit too low.
Harvard/bronco/champ/Princeton transformers might be fine. Hammond 270DAZ is close. I think I have access to an ao-44 transformer that might be fine, maybe slightly low on current.
angelodp
Post by angelodp »
So that 270DAZ puts B+ closer to 200, might be just fine, has enough current capability. You think this is the best option?
A
