troubleshoot after recap
thetragichero
Re: troubleshoot after recap
Post by thetragichero »
pdf64 wrote: Fri Sep 09, 2022 3:25 pm But it’s still asking for trouble to probe output valve anodes.
pin 3 is AWFULLY close to pin 2. thankfully i always use 100r artificial center tap resistors because I've sorted pins 2 and 3 with my meter lead before :roll:
I've started measuring at the ot center tap
pdf64
Post by pdf64 »
thetragichero wrote: Sat Sep 10, 2022 12:54 am
I was thinking from the perspective of oscillation, but yes, it’s all too easy for a regular probe tip to slip off a valve socket terminal and risk nasty shorts.
I think it’s good practice to use suitable clip on probe adapters, and ideally / especially for inexperienced, clip them in place before powering up.
