JMI AC30/6 NO SOUND
Re: JMI AC30/6 NO SOUND
Post by Stevem »
That amp is very hard on rectifier tubes!
Be sure to but one that has the glass the same diameter as the black plastic base.
Other ones not made as such are not real 5AR4 / GZ34 tubes, but glorified 5Y3GT tubes.
pdf64
Post by pdf64 »
Travis8 wrote: Tue Aug 10, 2021 5:08 pm Could be better buy this one?
https://www.tubeampdoctor.com/en/tad-so ... -rectifier
For goodness sake, no!
That will put the output valves etc under far more stress.
The sales text seems extremely misleading to say the least, ie that the solid state module can just be straight swapped with the rectifier valves listed.
Travis8
Post by Travis8 »
Stevem wrote: Tue Aug 10, 2021 7:43 pm That amp is very hard on rectifier tubes!
I had Sovtek 5AR4, if I use JJ GZ34/5AR4 It would fit?
Post by Stevem »
Yes, and the JJ is of a better internal construction then then Sovtek.
Travis8
Post by Travis8 »
Stevem wrote: Tue Aug 10, 2021 10:03 pm Yes, and the JJ is of a better internal construction then then Sovtek.
I changue it and It´s works and sound, but every 40 seconds or If I turn off and on quickly it blow the Main Fuse. (Not HT FUSE)
Travis8
Post by Travis8 »
mI can turn on and play a little but it blow fuses every 40 seconds.
Every time it blow one fuse a Blue Shine come from tubes
Post by Stevem »
It sounds like one of the 4 output tubes are bad and since you do not have a tube tester or another amp to prove them out in all you can do is to order up a new quad of them.
johnnyreece
Post by johnnyreece »
Travis8 wrote: Thu Aug 12, 2021 2:57 pm
Just a tip: Depending on what you mean by "quickly", that can toast a rectifier tube. You want to give the rectifier time to cool before switching it back on, or it can flash over. 30 seconds or so should be plenty.
pdf64
Post by pdf64 »
HT fuses are great, but their rating needs to be chosen with a modicum of thought; T500mA in an AC30 is pretty pointless.
Mine runs fine on F250mA.
And why put it after the rectifier? As it is, it’s completely missing a likely, high potential failure mode, ie GZ34 anode to cathode short.
Travis8 wrote: Thu Aug 12, 2021 2:57 pm…I changue it…
Do you know that the new rectifier is good? eg have you got another amp you can try it in?
Does the fuse hold if all EL84 valves are removed?
Travis8
Post by Travis8 »
Stevem wrote: Thu Aug 12, 2021 5:05 pm It sounds like one of the 4 output tubes are bad and since you do not have a tube tester or another amp to prove them out in all you can do is to order up a new quad of them.
Today I changue the fuse and now it doesnt blow any fuse
Rectifier is working good and everything is working, but still getting no sound :(
I try new power tubes and the problem still there :/
This is frustrating
Post by Stevem »
All your fuse blowing may have over loaded and now opened the power transformer.
pdf64
Post by pdf64 »
You need to go back to checking idle VDC at relevant circuit nodes, eg EL84 cathodes, preamp valve anodes.
Travis8
Post by Travis8 »
The amp is working now.
The rectifier was bad, HT Fuse too and one resistor was open.
Thanks you guys :)
