Ok. Rebuilt output sockets. Checked ever ground to every other ground. Looks good. Installed new bias pot (much better action!) heated the amp up and started checking.
No bias reading on either output socket @ 1Rs.
I looked at the tubes. They looked kind of dark. I plugged in and it sounded like a poor joint on an early cathode.. but no output hiss. It only made sound if I thrashed the guitar. Like an octavia with a dead battery even..
SO.. I started turning the bias pot toward the positive. I got a .1 then a .2 then a .3 and when I arrived at a .4 reading at the 1R, I played.
The output is in cutoff when the amp tells the meter it has a .4 mV condition at the bias reading point.
This board had some obvious mistakes when I bought it built as a JTM45 RI replacement. I think I should remove the board, rebuild the bias section, and run all new bus wiring if for no other reason than to set my mind at ease, that is if you don't have some great idea to talk me out of it.
I have much patience. All the voltages are just as described earlier. Even with the GAIN at 0, it passes some signal, enough to do the cutoff sounding output with the output at around 3. Increasing the gain helps to push enough signal so it just sounds like it is in powerstage cutoff for 2x as long. Readings make no sense.
Dunno. I read everything about everything and I am still unsure. Should I suspect a problem with this brand new output transformer? I don't know. You tell me.
