NO.playonit wrote:On the layout you did... do you have 2 wires connected to pin 2 one going to the front center tab the other going to back center tab on the MV pot?? that's the way I hooked it up.
2 wires are connected to pin 2.
One goes to the front center tab of the MV pot.
The other goes from pin 2 to the junction of the 1.5K grid resistors which connect to one pair of EL84 tubes.
I used pin 2 on the board as a junction point, but you really don't have to use it. You can connect a lead straight from the front center tab of the MV to the junction of the 1.5K grid resistors on one pair of EL84 tubes. Then pin 2 will have nothing connected to it.
The rear center tab of the MV pot has a lead straight to the junction of the 1.5K grid resistors for the other pair of EL84 tubes. The 1.5K grid resistors connect to "pin 2 on the EL84 tube sockets" - not pin 2 on the turret board.
Another potential problem - Pin 4 on the turret board originally had a wire connecting to one pair of 1.5K grid resistors for the EL84s. You need to disconnect that wire.
