	Moderators:  pompeiisneaks , Colossal
								Travis8
		Posts:  51  		Joined:  Sun Aug 08, 2021 8:47 am
						Post
								by Travis8   »  Tue Aug 10, 2021 12:49 pm
			Stevem  wrote: ↑ Tue Aug 10, 2021 10:27 am
On your 3rd output tube socket from the left it looks to me from your last photo that pin 3 is shorting to pin 2 .
I check It and there is not sorts
Violet to chasis and yellow to chasis around both 0.6 vdc
Travis8  on Tue Aug 10, 2021 2:04 pm, edited 1 time in total.
								pdf64
		Posts:  2932  		Joined:  Sat Mar 12, 2011 9:23 pm
						Post
								by pdf64   »  Tue Aug 10, 2021 1:17 pm
			Travis8  wrote: ↑ Tue Aug 10, 2021 12:49 pm
Violet to chasis and yellow to chasis around 0.6 vdc
Oh yes, it would be, so many posts!
Travis8  wrote: ↑ Mon Aug 09, 2021 5:07 pm
Fuse it's okey, pin 8 of rectifier 0.640 vdc
It looks like your GZ34 rectifier may be bad.
Does it get hot?
								Travis8
						Post
								by Travis8   »  Tue Aug 10, 2021 1:55 pm
			It's sovtek 5AR4 I turn on and wait some minutes.
It's light and It's hot
								Travis8
						Post
								by Travis8   »  Tue Aug 10, 2021 3:54 pm
			In summary:
Preamps valves:
Pin 1 to GND: around 0.685 VDC
Pin 6 to GND: around 0.740 VDC
Pin 9 to 4/5: 6.40 ACV
Rectifier:
Pin 8 to GND: 0.640 VDC
Pin 4 to GND: 282 ACV
Pin 6 to GND: 283 ACV
Pin 2 to Pin 8: 5.14 ACV
Choke/Big Cap to GND: around 0.6-0.7 VDC
								pdf64
						Post
								by pdf64   »  Tue Aug 10, 2021 3:59 pm
			Either the HT fuse, the rectifier valve, or related connection, is bad.
3 1/2 pages to get here, yikes!
								Travis8
						Post
								by Travis8   »  Tue Aug 10, 2021 4:02 pm
			pdf64  wrote: ↑ Tue Aug 10, 2021 3:59 pm
I try it with new fuse, maybe it´s rectifier valve.
How can I check it before buy one?
								sluckey
		Posts:  3528  		Joined:  Sun Jul 22, 2007 7:48 pm
						Post
								by sluckey   »  Tue Aug 10, 2021 4:13 pm
			Travis8  wrote: ↑ Tue Aug 10, 2021 4:02 pm
Take the fuse out. Measure the VDC on pin 8 of the rectifier tube.
								Travis8
						Post
								by Travis8   »  Tue Aug 10, 2021 4:24 pm
			Around 90-100 mV without fuse
								sluckey
						Post
								by sluckey   »  Tue Aug 10, 2021 4:51 pm
			sluckey  wrote: ↑ Tue Aug 10, 2021 4:13 pm
Just to be crystal clear, I'm talking about taking out the HT fuse.
Travis8  wrote: ↑ Tue Aug 10, 2021 4:24 pm
If you removed the HT fuse then that rectifier tube is dead.
								Travis8
						Post
								by Travis8   »  Tue Aug 10, 2021 4:59 pm
			sluckey  wrote: ↑ Tue Aug 10, 2021 4:51 pm
Yes, I remove the fuse and that was the VDC
								Travis8
						Post
								by Travis8   »  Tue Aug 10, 2021 5:00 pm
I'm going to buy new one (5AR4) and try It.
								sluckey
						Post
								by sluckey   »  Tue Aug 10, 2021 5:19 pm
			BUY A GZ34 TUBE!!!
And, you don't have to remove the entire fuse holder just to remove the fuse. That's kinda like removing the tube socket to remove a tube!
								Travis8
						Post
								by Travis8   »  Tue Aug 10, 2021 5:20 pm
			sluckey  wrote: ↑ Tue Aug 10, 2021 5:19 pm
BUY A GZ34 TUBE!!!
I didn't remove the fuse holder, just the fuse! XD
Ok I will buy one 5AR4 like the ones it's bad
								sluckey
						Post
								by sluckey   »  Tue Aug 10, 2021 6:23 pm
			Travis8  wrote: ↑ Tue Aug 10, 2021 5:20 pm
Phew! That's good. My mistake.
