pdf64 wrote: ↑Fri Mar 05, 2021 3:22 pm
Stevem wrote: ↑Thu Mar 04, 2021 9:20 pm
... I had a Bassman right in front of me with its standby switch wired in like his fuse in the PTs V+ center tap did not make for high voltages like he is having when the standby switch was open ,and I should have by what your last post is presuming!
There are several dozen different variants of Bassman designs, containing just about every possible permutation of valve amp circuitry. So for me to have any chance of helping you, please link to the appropriate schematic
OK, in the absence of that, I'll assume you've got an AA864; the same should apply to most models with a bias supply fed from a ~50V tap taken from two phase HT winding; specifically not a cathode biased 5B6 nor a 70W or other model with a separate bias winding.
https://el34world.com/charts/Schematics ... ematic.pdf
Modded such that its SPST standby switch has been moved from between the feed from the reservoir cap to the rest of the HT system, to the 0V return of the HT winding's CT.
Hence the HT line will be referenced to 0V via the 440k resistance of the reservoir caps' balancing resistors.
And with the standby switch open and the CT open circuit, a loose, high impedance 0V for the HT winding will exist via the bias supply, so effectively 355-0-245. A film reservoir cap then and open circuit at the HT rectifier output (ie as per the 6H100) would result in maybe 500VDC across the reservoir cap. However, the 440k balancing resistive load and various other leakage paths, in combination with the high impedance to 0V of the bias supply, will cripple that, such that there may only be a few VDC appearing in standby mode.
Compare that that the 6H100; as I explained previously
with CT open (and hence no current draw) the 0V reference would move to the HT leg connected to the bias supply, and the arrangement would resemble 680VAC at a very high source impedance, which would then be half wave rectified. Hence in that scenario, the VDC at the rectifier output can be much higher than normal.
Hence I think that if you arrange your Bassman's standby and HT & bias supplies as per the 6H100, and open the HT winding's CT return to 0V, you will be able to measure a very high VDC too.
