looking for a good trem/ verb unit schematic
sluckey
Re: looking for a good trem/ verb unit schematic
Post by sluckey »
In the early Gehring circuit V1B was a cathode follower similar to the 6G15 reverb unit. But the CF did not provide enough guitar signal to the vibrato modulator circuit so Tore T changed it to a gain circuit to provide a bigger signal to the modulator. The output of the modulator was then attenuated to get back to instrument signal level just before being mixed with the reverb signal.
The red components in the V1B circuit provide the necessary gain and the red components at the output of the modulator provide the necessary attenuation.
Two Alpha
Post by Two Alpha »
Thanks for the explanation sluckey, I hadn't really looked at the Tore T mods, didn't twig that they were on the same section that I was wondering about.
teemuk
Post by teemuk »
I think the idea hasn't popped up in this thread yet...
...but whenever you have a unit that incorporates both LFO-based amplitude modulation and a spring reverb it practically begs for "ghetto" echo effect implementation too: amplitude modulate that "wet" reverb signal instead.
tubeswell
Post by tubeswell »
teemuk wrote:I think the idea hasn't popped up in this thread yet...
Background guitar is a 6G15 going into a 5G9
Two Alpha
Post by Two Alpha »
teemuk wrote:whenever you have a unit that incorporates both LFO-based amplitude modulation and a spring reverb it practically begs for "ghetto" echo effect implementation too: amplitude modulate that "wet" reverb signal instead.
That's pretty standard for Fender though isn't it, the reverb was always before the tremolo, so why not in the revibe?
Two Alpha
Post by Two Alpha »
Now that I've finally completed a layout in diylc for a 6G15 with the 6G12-A tremolo circuit added, it strikes me that by converting it to a reverb into tremolo setup I will be able to use the second half of the extra 12AX7.
Might not be able to fit it all onto the ReVibe board though.
Two Alpha
Post by Two Alpha »
Here's where I've gotten to, 6G15 into that Tore T gain stage, into a 6G12-A tremolo, in series like back in the day.
Any suggestions or improvements?
sluckey
Post by sluckey »
Two Alpha wrote:Here's where I've gotten to, 6G15 into that Tore T gain stage, into a 6G12-A tremolo, in series like back in the day.
RE, your schematic...
V4B needs a grid leak resistor.
Two Alpha
Post by Two Alpha »
Got it, many thanks sluckey.
