I kind of agree (re: fwd biasing the grids), yet, I have used this same PI (Fender style) and output stage before without this problem, and, it appears in countless Fender AB763's..So, I can't figure-out why this particular amp is misbehaving this way.Jana wrote:My two cents.
It looks to me like your phase inverter is driving the grids of the power tubes into saturation. That "nipple" is a tell-tale sign of that (cold showers will do it too). I suggest reducing the gain of the PI so that the phase inverter will start to clip before its peak voltage swing exceeds the bias voltage. That way, the grids of the power tubes will never be driven positive (when they are driven positive, they start to conduct current which the phase inverter cannot supply--hence the nipple).
You might try increasing the size of the dropping resistor in the B+ string (the one between the choke and the PI node).
power supply voltages are:
center tap of OT: 452V
screen grid supply: 450V
phase inv supply: 429V
preamp supply: 385V
WHy should fwd biasing the grids cause a low frequency (almost sounds like 60Hz) artifact?
