Tweed Overdrive Special
mat
Re: Tweed Overdrive Special
Post by mat »
10thTx wrote:
The fever I'm suffering might have caused a 'few' strange note selections
Well, is that fever contagious and can I have some please?
:D
10thtx
:lol: Here comes: http://soundclick.com/share?songid=9708220
mat
10thTx
Post by 10thTx »
That is one serious awesome groove with great tone and playing. Very nicely done. also enjoyed the playful comic relief ending after such a seriously cool vibe.
With respect, 10thtx
Drumslinger
Post by Drumslinger »
I'm gonna have to make this my next project after i'm done with these other 3!! LOL
ampdoc1
Post by ampdoc1 »
I'm kinda behind the curve here, but I remembered this looked interesting.
I've got an open chassis and I'd like to try my hand at this amp,...like the novel changes and the sound clips here.
Is the schematic on page one the "end" design?
Thanks,
a'doc
EDIT:
What did you use for the dual 250k pot?
10thTx
Post by 10thTx »
IF you have ExpressSCH (free download), there is some up to date information here including an editable schematic & layout and bill of materials:
http://www.el34world.com/Forum/index.php?topic=9636.0
And some other information here:
http://www.el34world.com/Forum/index.php?topic=9638.0
And yet another great tone soundclip by DaGeezer here:
http://www.el34world.com/Forum/index.php?topic=10305.0
10thTx
Post by 10thTx »
I added an active effects loop onboard to one of the Tweed Overdrive Specials that I built. I like it ALOT! I'm running digital delay thru it and it gives it a very clear HUGE tone.
I opted to use Dana Hall's VVR in both of my TOS builds instead of the dual gang 250k. However, DaGeezer reports being very pleased with the PPIMV using the dual gang pots.
The 10-02-10 is the last schematic I got from DaGeezer & he is now using EL34's.
The schematic with the VVR is mine & I use some different values in my build (much as some of the Dumble clone builders use values to suit their personal tastes).
mat
Post by mat »
Hi 10thtx,
I had finally chance to try my TOS- build at band reherseals and was very pleased how it sounded. I changed the 470R's at power tubes to as high as 3k9's and the amp sounds very, very good now. I was about to record clips but our Presonus Firepod audio interface turned out to be broken :cry:
The power amp has been quite tight sounding during all dumble versions that has been on the box but now it works really good. I think Your cathode bias amp might not need 3k9's in there but my amp sounds really good with them.
Thanks again for the very inspirational amp design ! I'll record a clip if I get the Firepod working.
mat
10thTx
Post by 10thTx »
Mat,
That is GREAT news! I find both of my TOS amps cut thru in a band mix even with loud keyboards and drummer.
I will definitely look forward to hearing some of your incredibly toneful soundclips! Everything you've done as been just stellar to me.
with respect, 10thtx
ampdoc1
Post by ampdoc1 »
Thanks everyone for the info. I have a design I've made once before that combines a TR Express pre with a Dumble OD section. It's very good, and my current build on it is awaiting some PC boards.
But,...from the design layout and the clips, I think this is the amp I've been wanting to build. I love the smoothness plus the harmonic "feedback" that seems to work well at fairly low levels. Started my chassis last night!
HOOOBOY!!
10thTx
Post by 10thTx »
Here is the schematic of one of the Tweed Overdrive amps with the effects loop onboard added. Check for errors.
Zippy
Post by Zippy »
10thTx wrote:Here is the schematic of one of the Tweed Overdrive amps with the effects loop onboard added...
Which B+ did you use?
10thTx
Post by 10thTx »
The schematic shown is the Tweed Overdrive that does not have the effects loop. I used it as the example because the other TOS has even more changes from the original design. I simply drew it to show how it's installed. The TOS that does have the effects loop has it installed just like this.
I used node B for both plates because the prior nodes are controlled by the VVR. It works fine for me & with delay gives the amp a huge tone.
rsalinger
Post by rsalinger »
Wow... this design sounds stellar. Hats off to 10thTx and Da Geezer.
The Tweed Overdrive Special just might be my next build... I can "dream", can't I?
I was just wondering... How much gain is there on tap?
And secondly... I've got all the components for a Quad el84 power amp (ala AC-30-4/ Stangray) sitting in a box, on the floor of my linen closet. Are there any thoughts/opinions as to the possible outcome of "marrying" the two? Thanks.
Rob
Music is an expression of the inexpressable ~ Vernon Reid, Musician.
10thTx
Post by 10thTx »
The TOS I have has lots of gain and can do the blooming thing reasonably well. I can sustain a note to feedback with the OD dialed in right.
I would ask Geezer about the EL84's with the TOS preamp. I think he tried that? I haven't.
da Geezer
Post by da Geezer »
EL84's are my favorite tube......I have run the TOS preamp into a 2xEL84 poweramp & it is excellent sounding.
If I built another, it would be with a 4xEL84 power section, with the ability to select between 2x or 4x tubes.
Tuned right, a 2xEL84 amp is REALLY LOUD with plenty of headroom for non-stadium gigs.
G
