No problem you have your hands full with your expanding amp models as well as the current production.
I can work on this based off of gathered info from conversions done by previous people, but each one seems to have gone different directions even as far as making a marshall 18w lite version.
I would rather try make mine as close as to what you did as possible.
Would be nice to get a Zwreck for Christmas............ : Are we allowed to start bugging Brent for pre-order yet?
The amp was used a a reverb amp for a Hammond organ. It had a light to reduce the incoming voltage and coils. See the bottom left circuit on the AO-35 schematic.
So many amps in different stages but I was able to get back briefly to this one.
Here is my basic faceplate, drilled faceplate holes and making a back plate for output jack next. Will replace 20-20-20-20 can cap and 25uf/25v coupling caps on board and rewire.
Has anyone used Dartantion's (?spelling) EF86 Lite IIB. '
Rather than building the Dr Z AO-35 version I am pressed go with the EF86 IIB and wanted to hear back on how this amps sounds, otherwise, I will go with 12AX7 in V1 for the traditional Marshall 18w Lite IIB.
Every once in a while I'll build an amp in my usual half-planned fashion, finish it up with zip ties and say "Damn, that came out clean!". That really is a good looking build Mark, I especially like that you stuck with the vertical board and didn't have to do too many floating parts.
I started this morning and just finished about 10 minutes ago or so. I decided I was just going to go with the Lite IIB. I was thinking of using CC but didn't have all the values I needed.
I tried to clean up the original tube sockets but ended up drilling the rivots and going new. Cleaning up the board was fun, love the smell of old solder and components.
This is one loud and great little amp, next I need to build a head cabinet.
Oh and how the hell can this amp be dead quiet with my wires right on top of each other, I don't know how I lucked out there.
i just finish making the ghia out of a ao35. mine aint as clean as yours but the was no way i could use the stand up board. the circuit ways to long and not enuff room on the board. mine looks a little like a birds nest but its dead quiet? i might crank it up later today to see how loud it is. still need to add verb and a boost to it.
Yeah the ghia circuit is quite different isn't it. I decided after I built a Marshall 18w two channel that I loved the first channel a lot so the Lite IIB was a natural choice for me.
Glad you got yours going.
Cliff, I am looking for Marshall values so I can make a list and send to see if I can get those values. I haven't done that yet and was going to get some from Steve Apexjr and probably still will get some from both of you if I can.
