EF86 internal shield
Re: EF86 internal shield
The dilithium crystal on the left transponder seems to be out of calibration.
Translation:
Looks good man!:lol:
Clips?
Thanks Tom, I hope she doesn't blow like Scotty always said!
Working on getting clips recorded for all my builds by my friend Steve when we get the first opportunity which will probably be in the winter time in Minnesota for sure ya know.
FunkyE9th
Post by FunkyE9th »
It looks good. Curious...Did you end up changing the PT?
FunkyE9th thanks I did not change the PT but I do plan to at some time this winter. So that I can have bias tap and change OT with ultra linear taps. I want this JTM tranny set for a Marshall build and for the Root 666 to have the correct circuit. I did like people said build it and play with and later change it out, has been a good experience and fun.
Rattler66
Post by Rattler66 »
i also have a RT clone is there any difference between a 0.1u coupling cap and 0.15u, i have two different schems showing two different values (ie. they are the two caps coming off the PI, thanks
