New F&T 100uf 350v caps: Tip Of The Week
dbharris
Re: New F&T 100uf 350v caps: Tip Of The Week
Post by dbharris »
WhopperPlate wrote: Sun Feb 18, 2024 4:53 pm
dbharris wrote: Sat Feb 17, 2024 6:44 pm
WhopperPlate wrote: Sat Feb 17, 2024 4:38 pm
Warm , singing , I like them for fender
Thank you! That should suit this amp nicely.
-Dan
Let me know what you think when they are installed ; cross examine our testimonies
Will do!
Roe
Post by Roe »
In an ac100, I tested the following F&Ts at the mains:
- 100uf 550v axial (special series for Frag Jan zuerst): fast, explosive response, good harmonics
- 2x 220uf 350v A series axial in series: slower, laxer. less aggressive and bold
All caps were slow-formed (voltage dropped to 2v across 100k resistor)
After going back and forth, there is a very clear difference. It affects response perhaps more than sound
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
TUBEDUDE
Post by TUBEDUDE »
I like measurements. They help me quantify what I experience. I wish I had that spectrum analyzer R.G. had, that function of my Rigol scope is limited.
I agree anything real can be measured. Maybe not with the gear and process available to all of us, but it can help identify and filter out the variables in our hearing due to fatigue etc. True too is the fact that certain components, or combinations thereof, exhibit qualities that we recognize after using them in 40 or 50 builds without any measurements. Those differences are noted repeatedly over so much time and differing conditions that they are experientially valid.
Most builders use favored components for specific responses, noisy resistors or less than optmal caps. The limiting aspect of its construction or performance gives it a certain desired quality.. I understand the use of these to emulate the response of an iconic circuit,
Personally, I try to use foil caps for whatever I can, and metalized foil in lieu of electrolytics. Just my preference. Of course this is not possible in a clone or a small chassis.
Most of all experimentation is good, I agree with Whopperplate, breakout the clip leads!
Guy77
Post by Guy77 »
Roe wrote: Mon Feb 19, 2024 10:14 am In an ac100, I tested the following F&Ts at the mains:
Thats a very good point in regards to response time difference in caps. I have also noticed this difference with the first 2 series caps in the power supply. The IC and the Nichicon were a bit faster than the F&T A series.
This was comparing the 2x 100uf 350v A series F&T to the 2x100uf 350v IC and Nichicon PS series.
BTW this what the F&T look like inside.
G.
bepone
Post by bepone »
is it possible to put 2ohms in series with the cap and re test (like increasing ESR for purpose)
Post by Mark »
TUBEDUDE wrote: Mon Feb 19, 2024 1:35 pm I like measurements. They help me quantify what I experience. I wish I had that spectrum analyzer R.G. had, that function of my Rigol scope is limited.
Yeah, I’m the same way. I use a Ditto to play passages of guitar so I know the signal is exactly the same. I tried playing and listening, but I don’t play something exactly the same so that can introduce false positives.
I like to record the results to examine them again. Typically the video camera.
Yours Sincerely
Mark Abbott
WhopperPlate
Post by WhopperPlate »
Mark wrote: Mon Feb 19, 2024 11:35 pm
Video camera test is my favorite for comparison . I like the idea of ditto to remove variables , but for myself those inconsistencies in playing actuality tell the whole story. I am a type of player that improvises mostly , so the way the amp responds and reacts under my fingers inspires entirely different playing one way or another . And even still , when I recite a passage of music certain setups will prevent my best .
In the end this is why I began building amps , in order to make myself an amplifier that supported and inspired my live playing. Many amplifiers can be setup to sound great , but feel not so great . Same goes for individual electronic components.
Charlie
R.G.
Post by R.G. »
Sigh.
Mark Twain
Post by Mark »
R.G. wrote: Tue Feb 20, 2024 11:53 pmSigh.
Fair enough, I know you have mentioned this sort of thing time and time again. I do have great respect for your work and your opinions, but I do hear a difference between ceramic and silver mica caps and the difference is always the same.
I don’t know why they sound different, but they do sound different, the silver mica seems to let more signal through.
I’m happy to have my ignorance dispelled.
I did find this You Tube recording where the caps sound much as muchness.
https://youtu.be/ifC2A5QkbRY?si=MAlrOq-Ec8iwpv-d
Yours Sincerely
Mark Abbott
bepone
Post by bepone »
There is a difference between laboratory technician and guitar player.. in listening but also perceiving the amp through playing...so this is true. There are people who are doing both worlds.
Then there are many many small things in playing which player can feel but lab tech not, like response in playing, slowness of the amp response, developing the harminucs during clean-crunch volume on the amp, where small difference in attack can be heard.. etc. million small things.
Also all the amps sound different, but im not sure that you can measure and what this (any kind of) measure will tell you if you are staring in it
Mark wrote: Wed Feb 21, 2024 3:02 am...I do hear a difference between ceramic and silver mica caps and the difference is always the same.
Confirmation bias, anyone? ;^)
Mark wrote: Wed Feb 21, 2024 3:02 amI did find this You Tube recording where the caps sound much as muchness.
Nice demonstration there, I hadn't heard that one before, and it's from a guy who is in the business of selling amp parts. Unfortunately, it's yet another of many such comparisons where some people claim they can hear a difference and others say there is none. This is the inevitable result unless more rigorous double-blind test protocols are followed, in which case history shows that whatever physical differences might exist in the components, differences in sound are not reliably perceived by humans. It is a little surprising in one way, and that is that there are measurable differences in the performance of the dielectric materials, and those do not seem to come out based on the inconclusive listener comments.
WhopperPlate
I see a general trend of technicians needing to see measurements in order to perceive any differences … especially counting those likes … nothing new or surprising really , same things I have been told my whole life by the arbiters of truth. It’s a good thing they don’t build my amps for me .
In the end it’s okay if you can’t hear a difference between a ceramic and a silver mica. The fact of the matter is many people apparently aren’t that sensitive . Hard thing to admit for most anyone if they take pride in their skills , but it doesn’t pay to disbelief the person with perfect pitch because you can’t find a tuner. Bruised egos can go both ways , and it’s easy to not be objective in the face of experienced testimony that contradicts our belief systems.
Charlie
WhopperPlate wrote: Wed Feb 21, 2024 6:27 pmbut it doesn’t pay to disbelief the person with perfect pitch because you can’t find a tuner.
Difference being, perfect pitch can be easily and repeatably tested and demonstrated.
WhopperPlate
xtian wrote: Wed Feb 21, 2024 11:33 pm
It’s an analogy. Either way considering everything I am not sure they would be believed if hypothetically there wasn’t access to tuner .
Charlie
R.G.
Post by R.G. »
Another difference is that history has shown that very often careful(*) testing of the people who hear differences finds that their ability to hear a difference vanishes whenever the testing can be methodical enough to pin down whether they actually hear a difference or are getting visual or other clues instead of only hearing.
That is - careful testing shows that it's the people's opinion that gets tested, not the actual hardware that the opinion is supposed to be about. Many ABX blind tests show that the choices made by Golden Ears are ...worse... than random guessing could be expected to produce.
I do like the comment "it’s easy to not be objective in the face of experienced testimony that contradicts our belief systems." How true, how true. Much of the subjective versus objective audio/hifi/listening controversy is that humans seem to be built in a way that makes them want to develop a belief system - to have faith in some position. Once that faith is formed, it may not change even in the face of extreme evidence to the contrary. I also like a comment from the Project Rho/Atomic Rockets web site in the "respecting science" section.
"I don't 'believe' in science. I trust science. Science works whether I believe in it or not."
That being said, I am sure that your personal perception is much better and more realistic than the historical testing experience, and that you can perceive more subtly and reliably than any repeatable measurements available now. And I'm sure that you personally have not fallen prey to any of the multiple human listening and cognitive biases that have been identified.
* Well-set-up testing to eliminate clues other than the actual sound.
Mark Twain
