gktamps wrote: ↑Tue Apr 25, 2023 5:01 pm
I re-read your first post, and am trying to figure out what your concerns are about DC on your AC power. Are you actually having mechanical hum from your transformer, or are you just trying to pre-empt such a potential problem? Do you have a large toroidal transformer that is humming from DC on the line? Have you actually checked for DC offset on the line?
None of that. As I said before, the builder showed a photo of a new amp he's selling and this device was plugged into it.. I asked him what it was and what it did, and got a
non-answer answer.
Upon researching it a little, I understood it removed DC from the mains coming into the amp. Curious about the device (which retails for about $150) I learned that I could build one to try out for about $50.
gktamps wrote: ↑Tue Apr 25, 2023 5:01 pmThere is so much written about various designs of DC blockers that are openly discussed, so you don't need to look into someone's "secret design" - just do a lot of reading to see if you need such a device, and what are the pros/cons of using one. There are plenty of adherents and plenty of opponents, so it's best to only address a problem, and then by using the best solution that doesn't potentially create new problems.
The schematic you requested offline is simple. There is much written about the selection of capacitors you should review, e.g. high ripple, low esr.
And that's pretty much the heart of the circuit used in the product the amp builder was using in his photos.
My issue is almost certainly RFI, rather than DC on the mains.. however, I have a pre-amp that uses a toroidal transformer, so a DC blocker my be useful to me with that device.
I live on a hillside in central Texas, and at the top of the hill is a 400' tall radio repeater antenna. I have built a couple of small devices and played with CL values and been somewhat successful in filtering it out by running this between my guitar and amp.
The trade-off is; When I get the component values tuned such that it completely eliminates the RFI, it also turns the guitar into a bass.
