I see I'm late to the continuation of this party.csjoyner wrote: ↑Thu Mar 04, 2021 12:02 amIs there an independent test i can do on the cap that would tell me if it is bad?Phil_S wrote: ↑Wed Mar 03, 2021 2:02 pm From the Weber website: WS1 8-pin Copper Cap. Diodes and Limiter only, No Sag. Vdrop: 1V max @ Imax: 1000ma
I also can't imagine how you can see 700v at pin 8. There should only be rectified DC voltage at pin 8. If input is 340-340, the maximum output would be (sqrt(2)*340)-1 = 480VDC. Maybe something is wrong with the copper cap?
I guess you could breadboard a replica of the power supply and see if the copper cap performs or not, but that seems like a waste of time and resources. Just go for the 1N4007's. You can buy a small package of 10 on eBay for about $2. If you filter out foreign sourced, you should have them in a few days. Example: https://www.ebay.com/itm/10pcs-1N4007-R ... SwVHpfNG2p
I see there is a raging debate over whether the PT is bad or not. FWIW, I am in the camp that believes the PT is OK, but that's neither here nor there and I don't see the mileage in debating it at this point. It seems to me that the simplest course is to get the 1N4007's and see if they fix the problem. There are at least two reasons to go this route. One is that the Weber website says the WS1 is out of stock, so you won't want to wait around until they get more of them, if they ever do. The other is that, if this works, then you can just move on to complete the project, and since it is such a simple thing to do, why not just do it? I see no down side to this. Also, what PDF64 suggests is easy to do, so just do that, too.
As Stevem points out, nodes A-E are all at the same B+ because there are no preamp tubes. I asked for these readings as confirmation. If there was a voltage drop, it would point to something wrong. There is nothing conclusive here. When you put the preamp tubes in the amp, you may find something. However, we still have the strange behavior of the basic power supply. This leads me to think that is where we will find the problem.
