winding output transformer
NickC
Re: winding output transformer
Post by NickC »
tsutt wrote:when i got to 7th grade the school counselor called me in and told me i would never amount to anything, so just stick to the program and you will get through. I remember that like it was yesterday. What a way to help a troubled kid. and it was all down hill from there.
Sorry to OP for going off topic, but this strikes a (dis)chord in me. :wink:
My high school counselor called my parents in. Then I got called out of class on the intercom. In the conference that followed, he suggested my parents send me to military school. Bastard.
Not meaning to brag, but I graduated in the top 10% of my class, so where he was coming from is anybodies guess. I suspect it was on account of me being a long-haired smart-ass at a time when that wasn't very acceptable or fashionable (late '60s).
Moral of the story, don't put much stock in what school counselors say. And sure-as-heck don't let them be the arbiters of your future.
tsutt
Post by tsutt »
Yes i didnt mean to derail, im jealous of the abilities here is all. And if i knew then what i know now i would have beat him severely.
Back to winding, sorry. wont happen again.
Colossal
Post by Colossal »
NickC wrote:Moral of the story, don't put much stock in what school counselors say. And sure-as-heck don't let them be the arbiters of your future.
Sage advice.
"...I have spread my dreams under your feet, tread softly because you tread on my dreams."
Partridge
sagitt
18watt OT
Post by sagitt »
I keep coming back to look. This is just awesome! I want one.
katopan
Post by katopan »
Very nice once again Sagitt. Beautiful work! I've got a couple of questions for you. What sort of paper are you using, how thick is it and have you treated/coated it? Also you mentioned using a very light tension for the start and end turns of each layer to stop them falling into the winding margin. Is that the only secret? Is it all about using just the right amount of tension? That's the only area I still have trouble with. I've tried varied amounts of light tension but may need to play around more on my next wind to get it right. I also wonder if my hand winder is making it more difficult to get light but consistent tension and if I'd be better putting a motor drive on my winder just for that reason.
Colossal
Post by Colossal »
Phil_S wrote:I keep coming back to look. This is just awesome! I want one.
Indeed! Great to watch (and learn about) the process. A real piece of art! Katopan, I've enjoyed your work as well! Keep it up guys.
No rubber boob?I'm disapointed
sagitt
Post by sagitt »
thank you guys!primary wire is 0.15mm,secondary 0.70mm.for insulation I use nomex 0.05 and 0.25mm and between two layers of secondary 0.18mm prespan,that is the green thing on the first image...Kato when you use two hand it is easier to control tension,you need to have electric motor or something...with lees tension on beginning and ending of layer I manage to wind it without wire slips away.sometimes it is not possible because as I said wire has mind of its own!
sagitt
Post by sagitt »
[IMG:600:800]http://imageshack.us/a/img14/2001/img7589zw.jpg[/img]I thin I can wind another one with that primary wire
:wink:
katopan
Post by katopan »
Thanks Sagitt. I might have to put a motor on my winder and see how it helps.
sagitt
Post by sagitt »
[IMG:800:600]http://imageshack.us/a/img580/503/img7597zd.jpg[/img]
[IMG:800:600]http://imageshack.us/a/img9/6954/img7591uz.jpg[/img]
this is compressor from my smd soldering rework station,I am gonna use it for varnishing,Ihad one broken down :lol:
sagitt
Post by sagitt »
just finished another one!6K6 OT with 5K2 taps,next is varnishing... [IMG:800:600]http://imageshack.us/a/img546/9656/img7638gz.jpg[/img]
[IMG:800:600]http://imageshack.us/a/img801/2782/img7640n.jpg[/img]
[IMG:800:600]http://imageshack.us/a/img845/562/img7644b.jpg[/img]
[IMG:800:600]http://imageshack.us/a/img9/1424/img7647em.jpg[/img]
C Moore
Post by C Moore »
I would REALLY appreciate Info/Photos regarding the varnishing process.
Thank You :)
katopan
Post by katopan »
Cool! Good luck with the vacuum varnishing.
I'm winding another set of 30W transformers and varnishing as I go again. But after that I want to do a 5W SE OT on a bobbin without sides and vacuum varnish after winding, like I did with the first ones I wound. I've been experimenting with tension and am getting better at making sure the end turns don't fall into the winding margin.
