xtian wrote:I finished my SEL build, and it works! Haven't played much, because of a loud 60Hz hum and evidently high voltages. Please lend your eyes, and look over my gut shots.
Should I add those 100R heater resistors after all? Also, Hammond suggests using the Black primary lead for lower voltates (instead of the grey one). Any other suggestions?
Congratulations on your new build dude! SE designs can be notorious for buzz and hum and more care must be taken to eliminate opportunities for it to occur because there is no phase canceling in the power stage as occurs in push-pull.
If your heaters are not ground referenced you may want to add the artificial center tap via a couple of well matched precision 100R. You can also elevate them to DC by connecting the cathode on the power tube to the junction of your filament artificial center tap and let the heaters reference ground via the cathode.
Additionally, consider your lead dress. I might be inclined to chopstick around, moving various wires around on your preamp tubes and see where the 60Hz hum might be getting induced. Check that any B+ wiring is well separated from nearby AC or, if they must cross, that they do so at 90 degrees. You also might want to unbolt your OT and rotate it and see if it is interacting with the field from the PT. Typically, PT and OT are oriented such that the laminations are perpendicular to one another and barring that, well separated. I'm not being critical of your build, just trying to throw out the typical suggestions that start when validating a new build and dealing with annoying hum. Try one thing at a time and make a note it it helps so that your approach is methodical and you aren't introducing more variability or forgetting what ground you've already covered.
[EDIT] p.s. I'm interested to see what you think of the Judge Roy Bean and His Brown Bear tone stack. Seems like there is a lot of potential there. I've been eyeballing the UberSEL schematic with great interest (scratching chin...)
