I like the design. What are the dimensions?
Looks like you received the Benson speaker......
Thanks Mike! Hmmm off the top of my head the baffle board was 18x18" then the chassis was 6.5" inside so.. approx 27"H X 19.5"W X 10.5" D with added board thicknesspullshocks wrote: ↑Tue Apr 27, 2021 3:59 pmI like the design. What are the dimensions?
Which layout did you use Mike?mikeywoll wrote: ↑Tue Apr 27, 2021 3:17 amVery interesting. I tried disconnecting the volume pot from the second stage and grounding the grid of the tube directly to ground. Signal still bleeds through. It must be happening up at the control pots. In the point to point layout, the controls are pretty far from the circuit and the layout physically separates the various stages. In the turret board layout as I built it, the controls are close to the circuit and different stages are near each other. Plenty of high impedance points near strong signals that allow the opportunity for bleed.CraigGa wrote: ↑Mon Apr 26, 2021 8:14 am Have you seen this post by Katopan Mike?
https://ampgarage.com/forum/viewtopic.p ... 33#p427333
Craig
The amp sounds amazing, plays great, and is stable at all volumes. I may rebuild this one in the future, point to point next time
Mike
I used BobL's layout. My amp looks very similar to his most up to date version, with a couple small changes. I moved a couple resistors off the board onto either the switches or tubes (the cross talk predates these moves). I have added some small ceramic caps to bleed RF at the input jack and from plate to cathode on the first stage and across the reverb recovery stage. I added 10K grid blocking resistors to the reverb tube to snuff RF. My pots are locally grounded at their stages of origin not the pot casing.CraigGa wrote: ↑Tue Apr 27, 2021 4:42 pmWhich layout did you use Mike?mikeywoll wrote: ↑Tue Apr 27, 2021 3:17 amVery interesting. I tried disconnecting the volume pot from the second stage and grounding the grid of the tube directly to ground. Signal still bleeds through. It must be happening up at the control pots. In the point to point layout, the controls are pretty far from the circuit and the layout physically separates the various stages. In the turret board layout as I built it, the controls are close to the circuit and different stages are near each other. Plenty of high impedance points near strong signals that allow the opportunity for bleed.CraigGa wrote: ↑Mon Apr 26, 2021 8:14 am Have you seen this post by Katopan Mike?
Craig
Mike
that's a great looking build. I've been following this thread. I've never made a point to point amp and this looks like a great projects. I'm also a fan of these kind of 6v6 low wattage amps. I love my tweedle dee for example and use it a lot in the studio.dorrisant wrote: ↑Wed Apr 28, 2021 2:53 am Well, I subbed in a cheap Chinese 2x 6V6 OT and it plays loud and clear.
Voltages are a little off from their targets but not by much... 340v on the 6V6 plates and 328v on the screens, 211v on the first stage plate, 207v on the second stage plate. These NOS CCs are a little off here and there so I will live with it, as is. No reverb in this one and I'm using the 6X6GT from the Bogen since the PT has no 5v tap.
I used AC for the filaments. Tied the filament CT to the power tube cathode pins for elevation. Quiet as a mouse... maybe less.
PI trimmer is set for about 4k.
I'm using what Mike found for the USA/British switch, lots of difference there. Super fat and glassy on the US side. Nice voicing on the British side too.
Gonna have to get a real OT in this thing and play through my good cabs to hear it for sure. Not bad at all though.
HSS Strat was great through it in all positions, each position distinct.
Now to wait for one of these OTs to pop up...
