Single tone knob question
Re: Single tone knob question
Oh it was a link on that page you linked to.
This:
http://www.muzique.com/lab/tone3.htm
FYL
Post by FYL »
AMZ? Which were you referring to?
dehughes
Post by dehughes »
Ooh....okay. A Big Muff Pi variation. I'm going to try one of those in my amp eventually...
Tempus edax rerum
dehughes
Post by dehughes »
Okay, so I tried a Big Muff Pi variation and it is close, but still too dark...hmm. I like the way it shifts, but it still doesn't open up the top end enough for me. I'll try a few more iterations and see what I come up with...
Tempus edax rerum
Andy Le Blanc
Post by Andy Le Blanc »
Thats the thing.... keep looking. I like the old vol. and tone best, but I'm always
looking for more to try and to use in conjunction.
lazymaryamps
dehughes
Post by dehughes »
Hey, could one essentially build a TMB tone network with resistors and capacitors, yet leave only the "Treble" pot as the Tone pot? That might work for my needs...
Tempus edax rerum
roberto
Post by roberto »
dehughes
Post by dehughes »
Cool, but I only have one pot to work with...
Tempus edax rerum
Andy Le Blanc
there's a few examples of that used by Wards/Airline. The scheme heaven
bargain bin. One knob TMB.
lazymaryamps
roberto
Post by roberto »
Simply do not use the boost pot.
Tone pot is a dual pot, so only one hole in the chassis. :wink:
This one is interesting.
From the Airline 9060A.
[IMG:787:800]http://i23.photobucket.com/albums/b392/ ... s9060A.jpg[/img]
dehughes
Post by dehughes »
Cool! Bargain Bin it is...I'll go have a look...
Now, the one drawback of installing a "full" tonestack is the loss of gain, yes? That is, the stock 6G3 circuit doesn't loose as much gain in the tonestack as it would if one installed a TMB tonestack, right?
Tempus edax rerum
dehughes
Post by dehughes »
OKAY! I think I'm nearly there. Here is what I have.
Normal Volume and Tone (1M, each) controls a la 6G3. The 500pf bright cap is reduced to 68pf (might move it to 100...I'll give my ears a rest and check back in tomorrow). The .01uf cap on the tone control is replaced with a [100k -> .047uf -> 6k8 -> Ground] setup. I like this! The channel has it's Brown Deluxe-y vibe yet isn't nearly as harsh as it was before. I'll tinker some more with the values, but this is getting really close...
See the attachment for what I'm using now (currently have a 68pf cap in there...). It's my first time using the software, so excuse the look...
Tempus edax rerum
Andy Le Blanc
That's a neat approach, I hadn't thought to tailor the tone cut end of the circuit like that.
The midrange that comes along with the 500p cap value does something,
the amp is geared to break up early. That might a good spot to use a
selector of some sort or switch, go between 100p and 500p.
What cap type are you using? ceramic or silver mica?
lazymaryamps
dehughes
Post by dehughes »
Andy Le Blanc wrote:That's a neat approach, I hadn't thought to tailor the tone cut end of the circuit like that.
I'm using a tacked-in 68pf silver mica, though I have many ceramics and polystyrenes lying about. When I get home (it's "park day" with the son today) I'll crank up the amp and see how it sounds...that's the final test...
Tempus edax rerum
