Which measurements? If the tubes show the same static and dynamic characteristics, it'll be pretty much impossible to reliably find subjective differences in proper double blind tests. But even tubes from the same batch show different chars...Following that line of inquiry, would it be fair to say that a Chinese tube with the same electrical measurements as a Mullard, Tung-sol, or Amperex Bugle Boy would be sonic equivalents?
If you only consider basic static chars such as Gm and current draw at lowish anode voltages, there could be huge subjective differences - for instance a misaligned grid modifies greatly the transfer function, and the amp will sound differently.
So the answer is could be, not would be.
BTW; Chinese tubes have been resold by a lot of large "manufacturers" under their own brands for decades, beginning with GEC shifting production of their KT66 and KT88's in the '70s. Yes, those muy expensivo Genalex Gold Lion big bottles at 1K a pair could very well be genuine *and* Chinese.
It can't : it's core would saturate real fast because it's not designed for DC current. Add a gap and try it in SE mode, it could work. Would it sound the same as a high quality OT? I don't think so.Or that a 120vac to 6.3vac filament transformer, which has a turns ratio of 19 to 1 and would have an impedance of ~2.9K ohms when driving an 8 ohm load, would be the sonic equivalent of a Heybour SE output transformer?
There are no boundaries : they run parallel tracks.Where is the boundary between science and art? Is there a boundary?
 Copper price has fallen and steel right with it so it must be labor.
