If you have a spare 5.0 VAC winding (or add a small transformer for five or six volts ac at an amp or so), build a simple voltage doubler, then regulate it back down to 6.0 VDC using a 7806 or similar chip, and you can enjoy the near silence DC filaments can offer. Hope we're not over the OP's head here.
DC heaters
- FUCHSAUDIO
hmm
This has been covered before, but I'll offer it up:
Re: hmm
If you have the current sure that works fine, you'll need double the current as well as much bigger caps.FUCHSAUDIO wrote:This has been covered before, but I'll offer it up:
I still say for $20 a switcher and you are done, or use a 25VCT and use 12V heaters
- FUCHSAUDIO
YUP
I'm running dual 6800 UF's per cap section, and it gives me plenty of overage from a 5.0 VAC winding. About ten volts DC, into a 7806, gives you plenty of overage to stay clean and hum free, and to not lose regulation if the line drops. One 7806 can handle a pair of 6.0 V 12AX7's, and you can mount on the chassis for "free" heat sinking...
Switchers are another option, although I prefer to stay analogue...
Re: DC heaters
I have bridge-rectified a 12.6V Radio Shack 1.2A transformer (seal off the center tap), regulated that down with a 7812 to 12V, and powered 3 12AX7s with it. 2 1000uF caps get the job done. I also use the chassis as a heat sink. Works just fine. Helped my Express be just a little bit quieter. At 12V I'm only using 0.45A for the 3 tubes, so the 1A capacity of the 7812 is not in jeopardy, nor is the 1.2A capacity of the transformer. As a bonus, the wiring is simpler - don't have to connect anything to pin 9. If I wanted, I could connect either pin 4 or pin 5 directly to ground and just run one 12V wire to all tubes.
Me: Just one more...
Re: DC heaters
I would use a LDO regulator since otherwise you could be the edge with punch through on a 7812, especially if the wall voltage dips a bit.mlp-mx6 wrote:I have bridge-rectified a 12.6V Radio Shack 1.2A transformer (seal off the center tap), regulated that down with a 7812 to 12V, and powered 3 12AX7s with it. 2 1000uF caps get the job done. I also use the chassis as a heat sink. Works just fine. Helped my Express be just a little bit quieter. At 12V I'm only using 0.45A for the 3 tubes, so the 1A capacity of the 7812 is not in jeopardy, nor is the 1.2A capacity of the transformer. As a bonus, the wiring is simpler - don't have to connect anything to pin 9. If I wanted, I could connect either pin 4 or pin 5 directly to ground and just run one 12V wire to all tubes.
