WhopperPlate wrote: ↑Thu Feb 22, 2024 10:46 pm
When I look at the sky and see blue..,I don’t need to believe it’s blue…
Yep - you get to experience that the sky is blue. I think you're missing a subtlety here. Just because you believe it's blue doesn't mean it's NOT blue. The sky can be and has been independently measured for luminosity (Egad! There IS light coming from up there!) and the spectrum of light coming out of it, in the blue range of the human visible spectrum. The sky being blue can be repeatedly measured and verified. So your belief is justified, and more importantly, it can be measured and explained outside the belief system.
If you review my posts, you might find that I was trying to get to a concise statement of what you observed, exactly, and how that could be measured and captured, with the aim to apply this new knowledge to other amps.
but if I disbelieved my own perceptions I would be committed to an asylum …
Probably not. I sometimes disbelieve my own perceptions and I haven't been committed yet. So we have at least one counterexample. But then our relatives and friends may be tougher on you than mine are, possibly.
I did explain that I know I ...can... be wrong, so for things where there is no technical background, I fall back on measurement. If an instrument designed for the purpose reinforces >>independent of my opinions<< that I'm right, I start to believe. If the measurements say no, you're not right, then I start digging harder for what is really happening.
somehow though its implied that when I hear a certain silver mica cap as brighter I should doubt myself because others have been wrong generally speaking when tested …
Not at all.
First, the issue that started this mess was the casual statement that a certain brand of resistor made an amp sound better in a certain way.
My response was to inquire how that could be.
Is the certain brand of resistor somehow different from other brands? How exactly?
Does it have a different frequency response? That is, does it depart from R = V/I at high frequencies, low frequencies, mid frequencies, where?
Does it distort? (insert carbon comp experience retelling here; they do distort under highly specific circumstances) At low voltages? High voltages? When it's cold vs when it's hot?
If either of these, how much? That is, where in that brand of resistor's characteristics does it depart from V = I * R, so we can nail down the effect and use it to build more better sounding amps.
Moreover, is one resistor of the favored brand in an amp enough to make it sound better? Or is it cumulative? Do you have to do them all? Are there any of the resistors in an amp that matter more (that one is right out of the CC resistor distortion stuff, BTW) and some positions that matter less? Does adding one resistor of the magi... er, favored,
brand improve any amp?
Are there magically bad/cursed resistor brands that would cause any amp to sound worse if you put one in?
It's one thing to say that Brand X resistors make your amp sound good. It's quite another to (a) define "good" (!!) and then to say HOW this magic works and how to use the magic wand ..er, resistor to make other amps sound good.
Mark Twain
