Diagnosing source of 100Hz hum
		Re: Diagnosing source of 100Hz hum
Does your HT center tap go directly to the reservoir cap negative?
				timrobertson100
SOLVED!
I knocked up a quick rectifier board and used the BY255 diodes I had to hand and the amp is *silent* in this mode.
Thanks everyone for looking and helping - really appreciate everyone's comments and advice.
						Thanks a million Bepone - your intuition was correct and I would not have got there without your help
					Last edited by timrobertson100 on Sun Dec 31, 2023 12:13 pm, edited 1 time in total.
Try running the B+ and ground leads from the FWB like this.
no problem, enjoytimrobertson100 wrote: ↑Fri Dec 29, 2023 1:14 pm SOLVED!
				timrobertson100
Not quite finished tidying up, but the rectifier ended up mounted on the side like this.
If it helps anyone stumbling on this thread - there seems to be no issue with these B+ leads bundled but note the wire running from the diodes is no longer in the bundle.
Thanks all - I'm going to finish tidying and then close this up.
(Martin - it looks like a FWB but it's just a FW rectifier. The other pair of diodes are a second FW feeding the bias circuit as per valve wizard)
                                            2 others liked this
I'm betting your problem was bundling the rectifier/reservoir leads in with the others, and that it would have been quiet if you just separated those out, with the
CT going direct to reservoir negative. No denying that making those long runs over to the main board isn't the best idea, though.
It was very difficult to see what you had there with leads bundled and under the boards. I thought FW at first from the diode layout on the board and 2550 scheme, but 2555 (diagram visible in your photo) had a FWB.
				timrobertson100
Thanks Martin
I had tried splitting out the rectifier lead and then moved all those around with a chopstick, but never tried moving the CT. I think you’re right that it was somehow getting onto b+ for V2 on that run, or under the diodes. I also wondered if changing the diodes may have been a factor.
