Silvertone 1484 Weird Issue
dorrisant
Re: Silvertone 1484 Weird Issue
Post by dorrisant »
sluckey wrote: Fri Jun 16, 2023 1:24 am Those Mod caps look like they were made for this old amp. Have you used enough of the Mod caps to have an opinion about them?
I've been using them almost exclusively for about 2 1/2 to 3 years. I have never had a failure and I think they sound closer to the vintage Mallory filters as opposed to F&Ts in a Fender circuit. Plus my wallet likes them too. Also, they are smaller than a lot of other offerings so they fit in smaller spaces.
Post by Stevem »
If you do find that your chasing down the issue into the tremolo circuit just note that there are two different schematics for these amps and the difference is in the tremolo circuit.
dorrisant
Post by dorrisant »
I don't think I've seen a different schematic... Can you post the differences?
Post by Stevem »
I will have to look at my schematics when I get home for you.
sluckey
Post by sluckey »
I would think since the speed pot does not affect your warble effect, the tremolo circuit should be eliminated from the suspect list. But you can prove it to everyone by pulling V6.
Post by Stevem »
Here’s the difference in the two trem circuits.
The 15 meg from pin 1 to 3 which I guess is applying feedback.
sluckey
Post by sluckey »
Could you post that entire schematic?
Post by Stevem »
Sure!
sluckey
Post by sluckey »
Thanks. The 15M looks like a band aid of sorts. That resistor is also present on the 1485 schematics.
Post by Stevem »
Sadly neither schematic shows a revision date.
sluckey
Post by sluckey »
Stevem wrote: Sat Jun 17, 2023 1:00 am Sadly neither schematic shows a revision date.
I found the same schematic on the Aspen Pittman CD. Your is much more readable.
Post by Stevem »
Mine two I got out of the 2nd Kendrick book.
dorrisant
Post by dorrisant »
sluckey wrote: Fri Jun 16, 2023 5:36 pm I would think since the speed pot does not affect your warble effect, the tremolo circuit should be eliminated from the suspect list. But you can prove it to everyone by pulling V6.
Pulled V6... that is not the source.
Post by Stevem »
I would like to ask you to check what your ac ripple voltage is starting at the first preamp power supply node and if it’s going up and down, or if it’s steady and report back on what you find.
dorrisant
Post by dorrisant »
Stevem wrote: Thu Jun 22, 2023 7:34 pm I would like to ask you to check what your ac ripple voltage is starting at the first preamp power supply node and if it’s going up and down, or if it’s steady and report back on what you find.
Will do when I get it back on the bench again...
