Common Mode DC Power Filter
WhopperPlate
Re: Common Mode DC Power Filter
Sound of silence . Is that a reference to what will never be posted ?
Charlie
I may never do a post power amp based on a pair 300b , using Surface as a pre-amp , as what was on my mind when I first captured the CM concept.WhopperPlate wrote: ↑Wed May 31, 2023 3:38 pm Sound of silence . Is that a reference to what will never be posted ?
I may, however, do a post power amp, based on a pair of 6L6 , which would not require a CM filament power supply.
Surface does not use the CM DC power filter, nor would a super-scaling 6L6 post power amp.
I am sure this answer may not be taken in the correct way, so I leave it at that....... ... . . . . .. ... ... ....
-g
WhopperPlate
- Colossal
5 others liked this
I pulled the plug fellas. He's been banned before too. He went by mooreamps back then.
pullshocks
FWIW, LED bias was discussed on the AX84 forum at least as early as 2003
Also described in Morgan Jones' Valve Amplifiers, but I don't know from what edition and the date it first appeared.pullshocks wrote: ↑Wed May 31, 2023 10:27 pm FWIW, LED bias was discussed on the AX84 forum at least as early as 2003
