Chassis Layout
JJH0906
Re: Chassis Layout
Post by JJH0906 »
thetragichero wrote: Thu Mar 03, 2022 2:17 am if you're going into an interface, replacing the 'top' resistor in the voltage divider with a resistor and pot (wired as a rheostat) will give you a bit more volume control in the event that your interface does not want such a hot input signal (did this for a fella for his amp). the OTHER thing to keep in mind is that guitar speakers are REALLY CRAPPY for full range audio, so they knock off a bunch of junk frequencies that sound absolutely awful so some sort of speaker sim/impulse response is absolutely mandatory if you're going to be recording from the line out (i'm sure you can bypass the 'lower' resistor with a cap if you want to make a fixed low pass filter, but you'll still likely want some sort of speaker sim on there)
the *other* good reason to have your line out just an attenuated feed from the output transformer is that you'll then capture whatever tone the output tubes are adding
This gentlemanay be your twin:
https://www.dougcircuits.com/lineout.html
JJH0906
Re: Chassis Layout
Post by JJH0906 »
Updated Chassis Layout:
Thanks for all of your comments, group! Based on the suggestions provided, I did the following:
* Moved all the tubes to the rear of the chassis away from the control pots
* Ditched the tube Line Out and will just use a resistor network off the Output Stage (see https://www.dougcircuits.com/lineout.html)
* Arranged transformers and choke 90° out of phase of each other
Other notes:
* Gain control is placed between the 12AX& triodes
* EQ is a typical TMB-type, the SHIFT was added based on Merlin Blencowe's circuit which can shift the frequency response (seemed like a neat idea)
* The FX Loop is parallel so the MIX in the rear of the chassis is to mix the wet/dry signal
Things to consider:
* Will likely put the DC filter/drop resistor network on the top of the chassis in the blank spot to left of choke
* Turret board for components will be mounted underneath chassis (or just lay in the bottom of the head cabinet... whatever works!)
As mentioned earlier, any further thoughts or comments are appreciated!
(Sorry that PDFs are sideways)
