JMI AC30/6 NO SOUND
Travis8
Re: JMI AC30/6 NO SOUND
Post by Travis8 »
No volts between 9 and 4/5
Travis8
Post by Travis8 »
pdf64 wrote: Mon Aug 09, 2021 8:44 am So have you got any decent HT voltage anywhere in the preamp chassis? eg on the big filter caps.
Nothing :/ I try some Big caps
Travis8
Post by Travis8 »
All valves and lamp turns on but not HT :/
Post by Stevem »
If the tubes are lighting up then you DO have voltage between preamp tube pins 4 and 5 which are jumped together and then pin 9, but that AC voltage, not D.C. Voltage like your testing on the other pins on the tubes!
I don't want to sound mean, or cut you down, if you don't know this simple basic detail then a can't see how when you introduce yourself here that you posted / stated that you build amps I am sorry to say.
Travis8
Post by Travis8 »
Everyone can make a mistake, I build some amps but I had a mistake now XD
Sorry you are right, it's voltage between 9 and 4/5 (6.40volts)
pdf64
Post by pdf64 »
Travis8 wrote: Mon Aug 09, 2021 8:59 am All valves and lamp turns on but not HT :/
OK, you'll have to see what's going on inside the power amp chassis.
There may be a problem around the rectifier or the choke.
What are the VDC on the can cap terminals?
Travis8
Post by Travis8 »
sluckey
Post by sluckey »
You forgot to connect the rectifier tube pin 8 to the filter caps! That explains no high voltage.
EDIT... Looks like the HT fuse is mistakenly connected to rectifier pin 4. Should connect to pin 8.
Travis8
Post by Travis8 »
Travis8
Post by Travis8 »
sluckey wrote: Mon Aug 09, 2021 12:40 pm You forgot to connect the rectifier tube pin 8 to the filter caps! That explains no high voltage.
It was working without problems with this wiring
sluckey
Post by sluckey »
Really! That would mean the PT yellow wires are the high voltage wires and the PT red wires are the 5 volt wires. That's a very unusual color code for a PT.
Travis8
Post by Travis8 »
sluckey wrote: Mon Aug 09, 2021 1:47 pm Really! That would mean the PT yellow wires are the high voltage wires and the PT red wires are the 5 volt wires. That's a very unusual color code for a PT.
Yes! How can I check if the problem is the choke or the rectifier?
sluckey
Post by sluckey »
Measure the DCV on pin 8 of the rectifier. Then measure the DCV on each choke lead.
But first, check the HT fuse.
Travis8
Post by Travis8 »
Fuse it's okey, pin 8 of rectifier 0.640 vdc
sluckey
Post by sluckey »
Measure resistance from pin 8 to chassis with power off. Should be very high.
Can you see the rectifier filament glowing?
Measure the ACV from pin 4 to chassis. Looking for approx. 300VAC.
Measure the ACV from pin 6 to chassis. Looking for approx. 300VAC.
Measure ACV ***BETWEEN*** pin 2 and 8. (This means one probe on pin 2 and the other probe on pin 8.) Looking for approx. 5VAC.
