I don't want to go with quads, just pair of output tubes.
Output RMS will vary from 15 W of the 6V6s, to 40-50 W of the EL34/6L6GC, up to 80 W of the KT88/6550s.
But of course everything can be scaled if you want to.
Octal based "universal tone test-bench" (power) amp
Re: Octal based "universal tone test-bench" (power) amp
That's absolutely true. However, I'm confident one can get sparkly dry 100W from a pair in AB push-pull. Requires solid 600V plate supply and a fairly high primary impedance output transformer.
Best .. Ian
560 V on plates and 300 V on screens are enough, and the load is around 4 kOhm:
https://frank.pocnet.net/sheets/086/k/KT88.pdf
But with here I’ve foreseen up to 500 V only for plates.
