pjd3 wrote: ↑Sat May 09, 2020 10:32 pm
NWorbetan,
Can you explain what you meant by "plugged an assumed number into a formula where the answer was supposed to go".
I've already kinda explained this once, but I'll rephrase it a bit and see if that helps any. I'm not a math teacher, so I'm doing the best I can here.
The one formula we're working with is:
P = S * T^2
P = primary impedance
S = secondary load
T = turns ratio
You started the thread with a transformer, and you knew that two of the taps were 4Ω and 8Ω, less than 3 hours later the schematic filled in the info that the third tap is 16Ω. So you already know what S is.
You learned how to measure the turns ratio, and you nailed it. So now T is taken care of.
The primary impedance is the answer you were looking for. You know S and T and needed to solve for P.
Unfortunately, what you did instead was plugged 4.3kΩ in to P and solved for S, which was the wrong direction to go.
nworbetan wrote: ↑Thu May 07, 2020 10:01 am
pjd3 wrote: ↑Thu May 07, 2020 3:13 am
And I did out the math according to a pair of 6L6GC's with a plate voltage around 425 - primary impedance of 4.3K ohms
Yep, probably operator error. Without seeing your math it looks like you got the turns ratio right, but then to find the reflected impedance you need to square the turns ratio and multiply it by the speaker load, like dorrisant explained.
You did your math correctly, which I gave you credit for right away, but you didn't do the correct math for the situation you were in. You knew the correct speaker loads, and you measured the turns ratio correctly. The only unknown left was the answer you could've and should've solved for. Instead you came up with this confusion because the numbers you expected to see didn't match the math that you did:
The Bogner Alchemist schematic calls out 3 taps of 4, 8 and 16 ohms on the OT secondary. Thats what I expected to see.
However, after applying a low voltage to each tap and measering across the brown and blue wire of the primary, and of course following through with the math, this is what I got:
Orange to Blk = 8.4
Yellow to Blk = 4.1
Green to Blk = 2.08
I did use a 1K resistor in series with the function generator output and measured the tap(s) input voltage at the taps, after the resistor. (I set it for a 1kH sine wave).
So this seemed to bring me to classic values except, the schematic shows a 4, 8 and an unused 16 ohm tap.
Ya think they just used a different OT with 2, 4 and 8 ohm taps? And I did out the math according to a pair of 6L6GC's with a plate voltage around 425 - primary impedance of 4.3K ohms
At first, I thought I thought the Fluke meter was maybe reading Peak ac voltage instead of P-P which the function generator clearly showed (P-P in big letters). But, I hooked the meter directly to the func-generator and set for one volt P-P, the meter read .708 volts which I had to take as an RMS p-p reading.
