Known designs with 1st stage LNFB?
Tony Bones
Re: Known designs with 1st stage LNFB?
Post by Tony Bones »
If you need to knock the gain down more, you could split the plate resistor into two series resistors and take the output off the junction. Fender did that with the second stage of the 6G3 Deluxe.
TUBEDUDE
Post by TUBEDUDE »
Deleted
tubeswell
Post by tubeswell »
Another Guild amp with LNFB at V1
(Edit: AKA virtual earth mixer in this amp)
tubeswell
Post by tubeswell »
Dano DM25
I tried several things and none got near what I really wanted so I reverted back to similar place where I started.
Tony Bones
tubeswell wrote: Tue Feb 05, 2019 1:40 pm Another Guild amp with LNFB at V1
Not only does it have LNFB around V1, but there is a NFB loop from the plate of the 4th stage to the cathode of the third stage. It's the same idea as in the Thunderbird that I showed, but without the switch complicating things.
roberto
Post by roberto »
You can add a potentiometer in series with by cathode bypassing cap and set the amount of degenerative feedback you want.
Based on standard Rk values, 25k log would be perfect imho for this application.
