Yes, when the input is shorted by the input jack socket, or by turning the guitar volume to zero, the first grid stopper is usually the main source of hiss.JazzGuitarGimp wrote: If I correctly understand thermal noise (which is questionable...) the lower the resistor's value, the less thermal noise it generates. Since the resistor in question is at the input to the first stage, whatever thermal noise it generates is subject to the highest gain the amp is capable of. It makes sense that you would want that resistor to be the lowest value possible without introducing other issues such as stability and RF admittance. ....
Merlin derives some figures for this in the 2nd edition of 'Designing Tube Preamps for Guitar and Bass' on pp 64-66.
I think with a 10k grid stopper the noise which the grid stopper resistor generates is less than the noise generated in the first triode.
It's difficult to say how low you can take the grid stopper resistance, unless you know the transmission frequency of the Radio Station you need to block.
I believe some high gain amps do away with the first grid stopper altogether and use a ferrite around the wire to try to keep out RF.
