I tried this on my powerscaled LP Standard amp. I set voltage down to approx 100v. With an 8 ohm speaker plugged into the 4 ohm tap, the amp pretty much sounded the same. I also tried it in the 16 ohm jack...it sounded slightly duller but not a big difference. I tried this with my guitar plugged direct to the amp an on the clean channel. The power amp is pp KT66's into a 8k primary toroidal OT.
Throughout the voltage range on the powerscale control, the amp retains most of its tonal character, minus the psycoacoustic effects of a loud amp.
I've been kind of curious as to how important impedence matching is in guitar amps. Guitars have a relatively narrow freq. range, so picking the primary impedence to get an operating point that provides maximum power/bandwidth isn't necessary like it is with hifi...or at least that's my understanding at this point.
OT Impedance Match with VVR
Re: OT Impedance Match with VVR
Steve
