How do you tell a customer...?
- Reeltarded
Re: How do you tell a customer...?
i don't see a problem. I have a 12 ohm penis.
Wow. C10Ns are about the nicest 10" speaker on the planet. Still there?dorrisant wrote:You are right. I'm officially going blind now.jjman wrote:The scheme in the link shows 10" (not 10 ohms.) Both in the scheme section and the parts list section. My The Tube Amp Book is 4.1 and I don't see it there.
I found this page: http://johnkvintageguitars.homestead.com/Thor.html
Its show 2-10" Jensen C10N 8 ohm speakers. Maybe the correct impedance won't be that much different after all.
- dorrisant
Yeah, of course.xtian wrote:Well, of COURSE you should specify the speaker DIAMETER on the SCHEMATIC! Duh.sluckey wrote:That schematic doesn't say 10Ω speakers. It says 10" speakers
You sure that meter weren't set to milliohmsReeltarded wrote:i don't see a problem. I have a 12 ohm penis.
Sixty-four mW heart & '64 deluxe .. .. .. ..cbass wrote:You sure that meter weren't set to milliohmsReeltarded wrote:i don't see a problem. I have a 12 ohm penis.
- Reeltarded
I use the shunt method and measure current directly.
- Reeltarded
lol
Bbbb
I have not done the math, but is that 2watt screen resistor big enough?
