Thanks Ian.
I'm not sure that Gibson drew it up the phase shift circuit correctly? It's different then their GA-83S, GAV1 and the Wurlitzer vibrato that Gibson copied it from. (It's different from Vox's version of Gibson's too.)
So I re-drew the GA-55V modulator/mixer circuit hoping to untangle it to see the circuit a little better, not sure it helped.
Here's 2 versions. The 2nd version I did because I'm thinking that the resistive dividers/grid leak R's of 510K/1m should be as close to the 6SN7's grids.
Do you think this circuit will work or did Gibson get the mixer/modulator part of the schematic drawing wrong too?
Thanks, Brad
Edit; I added a re-drawn Wurlitzer vibrato circuit to compare with.
Gibson GA55V schemo
Re: Gibson GA55V schemo
The first few were obvious & easy to confirm. I'm on the road with limited time & tools. I'd need to spend more time closely analyzing, or go to the effort to build a spice model before knowing if are any issues hiding inside phase shifter. Looked at it for five minutes just now; seeing nothing obvious?
Best .. Ian
Best .. Ian
Thanks Ian for having a look at it.
I'm working on a bread board so when I finish it I can put the circuit on it and see if she fly's.
But if she doesn't I'll have no idea what might be wrong.
Gibson's GA-83S does work as Vox copied it for their AC15/30's.
I was thinking that Gibson found a little different way to wire up the mixer/modulator phase shift circuit as the GA-55V is different then their GA-83S and GAV-1.
And if I can get the 55V running on the bread board I will A/B it against the 83S to see if 1 sounds noticeably better than the other.
Thanks, Brad
Thanks, Brad
Hey Brad, good to see ya over here. My offer still stands if you guys make it down this way. Bring some of yer amps too.
Hi cbass!
Some fine day we'll go back down to Ark. and thank you we will drop in and see you.
Brad
Brad
