They said there would be no math.Phil_S wrote:It seems to me, all this can be figured using Ohm's Law. If you give me a schematic (as built) with a complete set of actual voltages, and provide the desired preamp voltages, I think I can get really close on the resistor values for the B+ ladder.
power supply dropping string potentiometer
- lord preset
Re: power supply dropping string potentiometer
(deleted)
Not arguing with you here...quite the contrary. The OP said he's fiddling with preamps. If we use Ohm's Law, that will give us the wattage (V*I) for each tube section. Using that wattage figure as if it is a constant will work to back-solve the problem. In reality, it is not a constant. It is the limited mA range on a 12A?7 that allows this to work. Besides, resistors come in standard values, so there is a forced choice when all is said and done.matt h wrote:The only issue with that is that current draw is also determined by plate voltage. If you're adjusting voltages within a narrow range, it may not matter a ton. It is conceivable within a narrow range of adjustment, you can rely on the current not to change enough where you can predict desired resistor values. If, however, you're trying to figure things out over a much broader sweep, resistance will start creeping in the opposite direction as current for the same voltage drop.Phil_S wrote:It seems to me, all this can be figured using Ohm's Law. If you give me a schematic (as built) with a complete set of actual voltages, and provide the desired preamp voltages, I think I can get really close on the resistor values for the B+ ladder.
Sorry Mr. Preset that you were absent from school on the day they covered this
(deleted)
I have a resistance decade box, it comes in handy to tune the preamp.
For more power I would probably go with a high wattage rheostat to dial it in.
Once you are satisfied, measure the resistance and replace with a fixed resistor of the proper wattage.
I like the decade box idea. Right now I just use alligator clips and a box of resistors. A bit reckless, but it does the trick. BTW, who is limited by standard values? What about parallel resistor combinations -- works great.Structo wrote:I have a resistance decade box, it comes in handy to tune the preamp.
Here I am wondering about all this. I'd still like to see the OP's schematic, voltage chart, and list of desired plate voltages. Maybe I can still salvage something?
beasleybodyshop
Phil, tomorrow I will re measure voltages and let you know.Phil_S wrote:Here I am wondering about all this. I'd still like to see the OP's schematic, voltage chart, and list of desired plate voltages. Maybe I can still salvage something?
