Split channel,off of first plate?
Re: Split channel,off of first plate?
TSC is wrong, correct value is a little bit above 600 Ohm.
- renshen1957
KOC uses transistors to mute each channel, works very well.V2 wrote:your original plan looks good to me. R7 is in series with R8, so there won't be a load problem on that arm.
Kevin O'Connor does something similar with his Standard preamp design.
Best regards,
Steve
Every Tom, Dick, and Harry is named Steve
How has that been identified? Is there anything obviously wrong with my test method (described previously)?correct value is a little bit above 600 Ohm
Blencowe explains the derivation of Zo for a CF in his Preamps book. It's given as 1/(1/Rk + 1/ra + gm). For a 12AX7 ra is 63k, and gm is 1.6 mA/V. Rk is typically 56-100k... gm dominates, so Zo is basically 1/gm = 625.
