You should measure your bias current, using shunt method, if you can, or dare... well you can use clip wires to your ammeter so you're not poking around inside while the high voltage is on.joshdfrazier wrote:After I grounded g3, the whooshing noise is gone. But I don't know if its because I replaced the 600v cap, cleaned all pins and sockets or what. Also, the hum is greatly reduced.
I think I'm going to tackle the bias circuit next. Something seems to be amiss, in order for it to burn out tubes like it did. I will also install a bias pot, probably 50k, once I figure out what's going on.
One lead goes to the output transformer center tap, and the other to one plate connection. As long as your meter's internal resistance is low compared to the OT's winding, you'll get a reading that's within a couple percent accuracy, close enough for rock and roll. For milliamps per tube, remember to divide the reading you get by 2 because that current is shared by the pair of tubes on one side of the push pull pair. Then measure the current on the other pair. If you get a figure between 50 to 80 milliamps per PAIR (25 to 40 mA per tube), you're in the right ball park. If it's beyond that, better have a go at that bias supply.
Something else to do - not a bad idea to install fresh bias supply filter cap now it's @ 40 years old.
