kanons wrote:Hello. I am trawling around for possible upgrades to my builds. I have just finished my Ampmaker N5X 5w single end amp. Great sounding Marshallish amp, but, as i have it full out at all times with the VVR controlling the WAF (Wife acceptance factor), it is a bit noisy and prone to the vagaries of the Norwegian mains. Rectifier is ss
Would a choke help filter out unwanted interference?
Any idea where I should put it
And: What data am I looking for if I should buy a choke?
I am also thinking of replacing all the caps in the power supply with known high quality stuff. Is this a waste of money/time?
1. Personally I always use a choke in a single ended amp because I find it much more efficient in smoothing out the ripple current - which I guess is the noise you are refering to.
2. On an SE I would use a CLC (Cap-Choke-Cap) filter set up before the B+1 OT / plate supply.
3. Maybe the best route for you is to order Merlin Blencowe's power supply book. After reading that you should be set.
4. You choose the mA rating to be at least and as close to the maximum mA that your circuit will draw.That amp can use several different tubes, so we cannot pull a number out of the hat for you right now.
5. There is a free programme called PSU designer which will let you get an idea of the results between different power supply designs before you bite the bullet. You can see the effect of different choke inductances, resistances etc. Expect choke inductance to be between 3H to 20H for guitar amps.
6. I also usually use SS rectification in a single ended design because there seems little point to me in an SE going for tube rectifier sag etc., etc.
7. The caps that Barry at Ampmaker supplies are fine for the task. If you sourced all from him then you may be wasting your spending changing them out. If you really need to, then go for the first reservoir cap - maybe throw a cool PEG Rifa in there or something like that.
hope that covers all the questions,
sorry cannot fix the power supply in Norway right now. Maybe they need a big choke up there.
tony
