Biasing Sovtek Mig-100
Re: Biasing Sovtek Mig-100
Yeah, it's probably the only trimmer pot in that amp.
Were these amps really made in Russia?
Yes with all Russian military surplus parts.  actually they are great amps. It's a ton of volume but with a power brake and a good cabinet these amps sing and take pedals better than any Marshall JCM800 I've heard.
Imported by new sensor and cloned by gibson's Red Bear
My Daughter Build Stone Henge
Yes its really a great amp. I'm really excited to get some new tubes in it and be able to work on it myself. I bought it for $400 in 9th grade, I will never sell it, it was my first tube amp and from what I hear it is a great amp to learn about amp design with.
Thanks for all your help.
Another question I have:
Do I need to have a load on the output when biasing or doing work on the amp that is not producing sound?
Yes. It is always producing some audio signal in the form of noise, but there is also the possibility of an oscillation. There's a good project for you- everyone needs a dummy load.
martin manning wrote:There's a good project for you- everyone needs a dummy load.
Any links you recommend?
As far as I'm concerned, any time a tube amp is powered up, there should be a speaker or dummy load connected.  I suspect most of us keep a cheap pair of 8 ohm speakers on the bench, easily reconfigured to 4 or 16.  If you aren't putting a signal through it, the power rating of the speaker is less of a concern though I guess it could still blow under the right (wrong) conditions.
Why take the risk? It is an ounce of prevention.
The best dummy load is a speaker with no cone (just the voice coil). It provides a proper impedance versus a straight resistance. And we all have semi-destroyed speakers laying around by now. But the voice coil has to be intact and functional: you can't use a speaker that you've fried; only one where the cone was damaged.
You don't need to load the output if no output tubes are installed, but obviously you can't bias an amp that way.
I got one of these.
[img:500:500]http://www.parts-express.com/images/pro ... -020_l.jpg[/img]
http://www.parts-express.com/pe/showdet ... er=019-020
Whoa! Okay I'm ordering one. Non-inductive, but very cool.Structo wrote:I got one of these.
Yeah, I mounted mine on a slab of aluminum to help the heat dissipation.
Be sure to get the right resistance for your amp.
Here's mine. Updated an old thread since this one is really another subject: https://tubeamparchive.com/viewtopic.ph ... 643#131643
Yeah, if Parts Express would have had a 300w load I would have bought that.
Perhaps putting two 100w 4 ohm in series would be safer?
I bought 2 so I can go 4-ohms, 8 or 16.Structo wrote:Yeah, I mounted mine on a slab of aluminum to help the heat dissipation.
Thanks for the suggestion.
Alright I got the amp opened up, immediately saw a fried screen resistor and replaced it. Measured resistance from P1:CT and P2:CT - Both 37 Ohms.
Plate voltage is at 545v, for which I calculated 38.5ma for each tube as per Weber Bias calculator (6L6GC) running at 70%, which for 2 tubes is 77ma. Calculated (.077*37) that I need a -2.85v drop from the CT to plate.
I am getting about a .3v difference between each set of tubes for this reading, so I set one reading lower to -2.8v and the hotter pair are at -3.1v
Am I missing anything?
