Here to scope pictures in overdrive showing the output and the signal at G1, one with and one without NFBWhat does the driver waveform at the power tube grid look like - stay unclipped?
- without NFB the G1 signal is not clipped
- with NFB it is even going higher. the reason is that at the moment of clipping the NFB signal is clipped. At that moment you get the open loop signal at G1 - which is higher than the closed loop signal. The second thing you can see is that the clipping is getting unsymmetrical. From my understanding this is caused by the LTPI no longer beeing symmetrical.
